FreeRTOS 202111.00 Release:
Symmetric Multi-Processing:
xTaskCheckForTimeOut()
[Task Utilities]
task.h
BaseType_t xTaskCheckForTimeOut( TimeOut_t * const pxTimeOut,
                                 TickType_t * const pxTicksToWait );
xTaskCheckForTimeOut() is used with vTaskSetTimeOutState(). vTaskSetTimeOutState() is called to set the initial condition, after which xTaskCheckForTimeOut() can be called to check for a timeout condition, and adjust the remaining block time if a timeout has not occurred.
pxTimeOut   A pointer to a structure that holds information necessary to determine if a timeout has occurred. pxTimeOut is initialized using vTaskSetTimeOutState().
pxTicksToWait   Used to pass out an adjusted block time, which is the block time that remains after taking into account the time already spent in the Blocked state.
If pdTRUE is returned then no block time remains, and a timeout has occurred.
If pdFALSE is returned then some block time remains, so a timeout has not occurred.
/* Driver library function used to receive uxWantedBytes from an Rx buffer that
is filled by a UART interrupt.  If there are not enough bytes in the Rx buffer
then the task enters the Blocked state until it is notified that more data has
been placed into the buffer.  If there is still not enough data then the task
re-enters the Blocked state, and xTaskCheckForTimeOut() is used to re-calculate
the Block time to ensure the total amount of time spent in the Blocked state does
not exceed MAX_TIME_TO_WAIT. This continues until either the buffer contains at
least uxWantedBytes bytes, or the total amount of time spent in the Blocked state
reaches MAX_TIME_TO_WAIT – at which point the task reads however many bytes are
available up to a maximum of uxWantedBytes. */
size_t xUART_Receive( uint8_t *pucBuffer, size_t uxWantedBytes )
size_t uxReceived = 0;
TickType_t xTicksToWait = MAX_TIME_TO_WAIT;
TimeOut_t xTimeOut;
   /* Initialize xTimeOut.  This records the time at which this function was
   entered. */
   vTaskSetTimeOutState( &xTimeOut );
   /* Loop until the buffer contains the wanted number of bytes, or a timeout
   occurs. */
   while( UART_bytes_in_rx_buffer( pxUARTInstance ) < uxWantedBytes )
      /* The buffer didn't contain enough data so this task is going to
      enter the Blocked state.  Adjusting xTicksToWait to account for any time
      that has been spent in the Blocked state within this function so far to
      ensure the total amount of time spent in the Blocked state does not exceed
      MAX_TIME_TO_WAIT. */
      if( xTaskCheckForTimeOut( &xTimeOut, &xTicksToWait ) != pdFALSE )
         /* Timed out before the wanted number of bytes were available, exit the
         loop. */
         break;
      /* Wait for a maximum of xTicksToWait ticks to be notified that the receive
      interrupt has placed more data into the buffer. */
      ulTaskNotifyTake( pdTRUE, xTicksToWait );
   /* Attempt to read uxWantedBytes from the receive buffer into pucBuffer.  The
   actual number of bytes read (which might be less than uxWantedBytes) is
   returned. */
   uxReceived = UART_read_from_receive_buffer( pxUARTInstance,
                                               pucBuffer,
                                               uxWantedBytes );
   return uxReceived;
