FreeRTOS 202111.00 Release:
Symmetric Multi-Processing:
Tasks
[More about tasks...]
Implementing a Task
A task should have the following structure:
        for( ;; )
            -- Task application code here. --
        /* Tasks must not attempt to return from their implementing
        function or otherwise exit.  In newer FreeRTOS port
        attempting to do so will result in an configASSERT() being
        called if it is defined.  If it is necessary for a task to
        exit then have the task call vTaskDelete( NULL ) to ensure
        its exit is clean. */
        vTaskDelete( NULL );
The type TaskFunction_t is defined as a function that returns void and takes a void pointer as its only parameter. All functions that implement a task should be of this type. The parameter can be used to pass information of any type into the task - this is demonstrated by several of the standard demo application tasks.
Task functions should never return so are typically implemented as a continuous loop. However, as noted on the page that describes the RTOS scheduling algorithm, normally it is best to create tasks that are event-driven so as not to starve lower priority tasks of processing time, making the structure:
        for( ;; )
            /* Psudeo code showing a task waiting for an event
            with a block time. If the event occurs, process it.
            If the timeout expires before the event occurs, then
            the system may be in an error state, so handle the
            error.  Here the pseudo code "WaitForEvent()" could
            replaced with xQueueReceive(), ulTaskNotifyTake(),
            xEventGroupWaitBits(), or any of the other FreeRTOS
            communication and synchronisation primitives. */
            if( WaitForEvent( EventObject, TimeOut ) == pdPASS )
                -- Handle event here. --
                -- Clear errors, or take actions here. --
        /* As per the first code listing above. */
Again, see the RTOS demo application for numerous examples.
Tasks are created by calling xTaskCreate() or xTaskCreateStatic(), and deleted by calling vTaskDelete().
[Back to top]
Task Creation Macros
Task functions can optionally be defined using the portTASK_FUNCTION and portTASK_FUNCTION_PROTO macros. These macro are provided to allow compiler specific syntax to be added to the function definition and prototype respectively. Their use is not required unless specifically stated in documentation for the port being used (currently only the PIC18 fedC port).
The prototype for the function shown above can be written as:
void vATaskFunction( void *pvParameters );
Or,
portTASK_FUNCTION_PROTO( vATaskFunction, pvParameters );
Likewise the function above could equally be written as:
    portTASK_FUNCTION( vATaskFunction, pvParameters )
        for( ;; )
