xEventGroupSetBitsFromISR()
[Event Group API]
event_groups.h
 BaseType_t xEventGroupSetBitsFromISR(
                          const EventBits_t uxBitsToSet,
Set bits (flags) within an RTOS event group. A version of xEventGroupSetBits() that can be called from an interrupt service routine (ISR).
Setting bits in an event group will automatically unblock tasks that are blocked waiting for the bits.
Setting bits in an event group is not a deterministic operation because there are an unknown number of tasks that may be waiting for the bit or bits being set. FreeRTOS does not allow non-deterministic operations to be performed in interrupts or from critical sections. Therefore xEventGroupSetBitFromISR() sends a message to the RTOS daemon task to have the set operation performed in the context of the daemon task - where a scheduler lock is used in place of a critical section.
NOTE: As mentioned in the paragraph above, setting bits from an ISR will defer the set operation to the RTOS daemon task (also known as the timer service task). The RTOS daemon task is scheduled according to its priority, just like any other RTOS task. Therefore, if it is essential the set operation completes immediately (before a task created by the application executes) then the priority of the RTOS daemon task must be higher than the priority of any application task that uses the event group. The priority of the RTOS daemon task is set by the configTIMER_TASK_PRIORITY definition in FreeRTOSConfig.h.
INCLUDE_xEventGroupSetBitFromISR, configUSE_TIMERS and INCLUDE_xTimerPendFunctionCall must all be set to 1 in FreeRTOSConfig.h for the xEventGroupSetBitsFromISR() function to be available.
The RTOS source file FreeRTOS/source/event_groups.c must be included in the build for the xEventGroupSetBitsFromISR() function to be available.
xEventGroup   The event group in which the bits are to be set. The event group must have previously been created using a call to xEventGroupCreate().
uxBitsToSet   A bitwise value that indicates the bit or bits to set. For example, set uxBitsToSet to 0x08 to set only bit 3. Set uxBitsToSet to 0x09 to set bit 3 and bit 0.
pxHigherPriorityTaskWoken   As mentioned above, calling this function will result in a message being sent to the RTOS daemon task. If the priority of the daemon task is higher than the priority of the currently running task (the task the interrupt interrupted) then *pxHigherPriorityTaskWoken will be set to pdTRUE by xEventGroupSetBitsFromISR(), indicating that a context switch should be requested before the interrupt exits. For that reason *pxHigherPriorityTaskWoken must be initialised to pdFALSE. See the example code below.
If the message was sent to the RTOS daemon task then pdPASS is returned, otherwise pdFAIL is returned. pdFAIL will be returned if the timer service queue was full.
#define BIT_0    ( 1 << 0 )
#define BIT_4    ( 1 << 4 )
/* An event group which it is assumed has already been created by a call to
xEventGroupCreate(). */
EventGroupHandle_t xEventGroup;
void anInterruptHandler( void )
BaseType_t xHigherPriorityTaskWoken, xResult;
  /* xHigherPriorityTaskWoken must be initialised to pdFALSE. */
  /* Set bit 0 and bit 4 in xEventGroup. */
  xResult = xEventGroupSetBitsFromISR(
                              xEventGroup,   /* The event group being updated. */
                              BIT_0 | BIT_4, /* The bits being set. */
                              &xHigherPriorityTaskWoken );
  /* Was the message posted successfully? */
  if( xResult != pdFAIL )
      /* If xHigherPriorityTaskWoken is now set to pdTRUE then a context
      switch should be requested.  The macro used is port specific and will
      be either portYIELD_FROM_ISR() or portEND_SWITCHING_ISR() - refer to
      the documentation page for the port being used. */
