Co-routines
[More about co-routines...]
Implementing a Co-Routine
A co-routine should have the following structure:
    void vACoRoutineFunction( CoRoutineHandle_t xHandle,
                              UBaseType_t uxIndex )
        crSTART( xHandle );
        for( ;; )
            -- Co-routine application code here. --
        crEND();
The type crCOROUTINE_CODE is defined as a function that returns void and takes an CoRoutineHandle_t and an index as its parameters. All functions that implement a co-routine should be of this type (demonstrated above).
Co-routines are created by calling xCoRoutineCreate().
Points to note:
  • All co-routine functions must start with a call to crSTART().
  • All co-routine functions must end with a call to crEND().
  • Co-routine functions should never return so are typically implemented as a continuous loop.
  • Many co-routines can be created from a single co-routine function. The uxIndex parameter is provided as a means of distinguishing between such co-routines.
