xSemaphoreGetStaticBuffer()
[Semaphores]
semphr.h
BaseType_t xSemaphoreGetStaticBuffer( SemaphoreHandle_t xSemaphore,
StaticSemaphoreBuffer_t ** ppxSemaphoreBuffer );
Retrieve the pointer to a statically created binary semaphore's, counting semaphore's, or mutex's data structure buffer. This is the same buffer that is supplied at the time of creation.
xSemaphore
The semaphore whose data structure buffer will be retrieved.
ppxSemaphoreBuffer
Used to return a pointer to the semaphore's data structure buffer.
pdTRUE if the buffer was retrieved, pdFALSE otherwise.
