message_buffer.h
void vMessageBufferDelete( MessageBufferHandle_t xMessageBuffer );
Deletes a message buffer that was previously created using a call to
xMessageBufferCreate() or xMessageBufferCreateStatic().
If the message buffer was created using dynamic memory (that is, by xMessageBufferCreate()),
then the allocated memory is freed.
A message buffer handle must not be used after the message buffer has been
deleted.
xMessageBuffer
The handle of the message buffer to be deleted.
