pcTimerGetName
 const char * pcTimerGetName( TimerHandle_t xTimer );
Returns the human readable text name of a software timer.
Text names are assigned to timers using the pcTimerName parameter of the call to xTimerCreate() used to create the timer.
A pointer to the text name of the timer as a standard NULL terminated C string.
const char *pcTimerName = "ExampleTimer";
/* A function that creates a timer. */
static void prvCreateTimer( void )
TimerHandle_t xTimer;
    /* Create a timer. */
    xTimer = xTimerCreate( pcTimerName,           /* Text name. */
                           pdMS_TO_TICKS( 500 ),  /* Period. */
                           pdTRUE,                /* Autoreload. */
                           NULL,                  /* No ID. */
                           prvExampleCallback );  /* Callback function. */
    if( xTimer != NULL )
        xTimerStart( xTimer, portMAX_DELAY );
        /* Just to demonstrate pcTimerGetName(), query the timer's name and
        assert if it does not equal pcTimerName. */
        configASSERT( strcmp( pcTimerGetName( xTimer ), pcTimerName ) == 0 );
