FreeRTOS 202111.00 Release:
Symmetric Multi-Processing:
FreeRTOS Counting Semaphores
Just as binary semaphores can be thought of as queues of length one, counting semaphores can be thought of as queues of length greater than one. Again, users of the semaphore are not interested in the data that is stored in the queue - just whether or not the queue is empty or not.
  1. Counting events.
    In this usage scenario an event handler will 'give' a semaphore each time an event occurs (incrementing the semaphore count value), and a handler task will 'take' a semaphore each time it processes an event (decrementing the semaphore count value). The count value is therefore the difference between the number of events that have occurred and the number that have been processed. In this case it is desirable for the count value to be zero when the semaphore is created.
  2. Resource management.
    In this usage scenario the count value indicates the number of resources available. To obtain control of a resource a task must first obtain a semaphore - decrementing the semaphore count value. When the count value reaches zero there are no free resources. When a task finishes with the resource it 'gives' the semaphore back - incrementing the semaphore count value. In this case it is desirable for the count value to be equal the maximum count value when the semaphore is created.
See the Semaphores/Mutexes section of the user documentation for a list of semaphore related API functions. Searching the files in the FreeRTOS/Demo/Common/Minimal directory will reveal multiple examples of their usage. Note that interrupts must NOT use API functions that do not end in "FromISR".
