xTimerIsTimerActive
BaseType_t xTimerIsTimerActive( TimerHandle_t xTimer );
Queries a software timer to see if it is active or dormant.
A timer will be dormant if:
- It has been created but not started, or
- It is an expired one-shot timer that has not been restarted.
Timers are created in the dormant state. The xTimerStart(),
xTimerReset(),
xTimerStartFromISR(),
xTimerResetFromISR(),
xTimerChangePeriod() and
xTimerChangePeriodFromISR()
API functions can all be used to transition a timer into the active state.
xTimer
The timer being queried.
pdFALSE will be returned if the timer is dormant. A value other than pdFALSE will be returned if the timer is active.
/* This function assumes xTimer has already
been created. */
/* xTimer is active, do something. */
/* xTimer is not active, do something else. */
