FreeRTOS 202111.00 Release:
Symmetric Multi-Processing:
FreeRTOS Kernel Ports
Hardware Partner Supported Processor Families Supported Tools
A
Altera Cyclone V SoC (ARM Cortex-A9), Nios II Altera SoC EDS (ARM DS-5 with GCC), Nios II IDE with GCC
ARMv8-M
Note this category is just for simulated targets. Other ARMv8-M targets are in their respective vendor categories.
ARM Cortex-M33 simulator GCC (and ARMclang building the FreeRTOS ARMv8-M GCC port)
Atmel SAMV7 (ARM Cortex-M7), SAM3 (ARM Cortex-M3), SAM4 (ARM Cortex-M4 ), SAMD20 (ARM Cortex-M0+), SAMA5 (ARM Cortex-A5), SAM7 (ARM7), SAM9 (ARM9), AT91, AVR and AVR32 UC3 IAR, GCC, Keil, Rowley CrossWorks
C
Cadence Tensilica Xtensa XCC with the Xtensa Xplora IDE
Cortus APS3 Cortus IDE with GCC
Cypress PSoC 5 ARM Cortex-M3 GCC, ARM Keil and RVDS - all in the PSoC Creator IDE
F
Freescale Kinetis ARM Cortex-M4, Coldfire V2, Coldfire V1, other Coldfire families, HCS12, PPC405 & PPC440 (Xilinx implementations) (small and banked memory models), plus contributed ports Codewarrior, GCC, Eclipse, IAR
I
Infineon TriCore, XMC4000 (ARM Cortex-M4F), XMC1000 (ARM Cortex-M0) GCC, Keil, Tasking, IAR
Fujitsu (Now Spansion) FM3 ARM Cortex-M3, 32bit (for example MB91460) and 16bit (for example MB96340 16FX) Softune, IAR, Keil
L
Luminary Micro / Texas Instruments. See also TI. All Luminary Micro ARM Cortex-M3 and ARM Cortex-M4 based Stellaris microcontrollers Keil, IAR, Code Red, CodeSourcery GCC, Rowley CrossWorks
M
Microchip. See also Microsemi (now Microchip). PIC32MX, PIC32MZ, PIC32MZ EF, PIC24, PIC24EP, dsPIC, MEC14xx, CEC13xx, CEC17xx, MEC17xx, MEC51xx MPLAB C32, MPLAB C30
Microsemi MiFive (RISC-V), SmartFusion, SmartFusion2 IAR, Keil, SoftConsole (GCC with Eclipse)
N
NEC (now Renesas) V850 (32bit), 78K0R (16bit) IAR
Nuvoton NuMicro M2351 (ARM Cortex-M23) IAR, Keil
NXP VEGAboard (RISC-V), LPC55S6x(ARM Cortex-M33), LPC1500 (ARM Cortex-M3), LPC1700 (ARM Cortex-M3), LPC1800 (ARM Cortex-M3), LPC1100 (ARM Cortex-M0), LPC2000 (ARM7), LPC4000 (ARM Cortex-M4F/ ARM Cortex-M0) GCC, Rowley CrossWorks, IAR, Keil, LPCXpresso IDE, Eclipse, MCUXpresso IDE
R
Renesas RZ/A1 / RZ/A2M, (ARM Cortex-A9), RZ/T, RX700 / RX71M, RX600 / RX64M / RX62N / RX63N / RX65N, RX200, RX100, SuperH, RL78, H8/S plus contributed ports GCC, e2 studio, IAR Embedded Workbench, HEW (High Performance Embedded Workbench)
S
SiFive RISC-V RV32 Freedom Studio (GCC), IAR
Silicon Labs [ex Energy Micro] EFM32 Gecko (Cortex-M3 and Cortex-M4F), 8051 compatible microcontrollers. Simplicity Studio (GCC), IAR, SDCC
Spansion FM3 ARM Cortex-M3, 32bit (for example MB91460) and 16bit (for example MB96340 16FX) Softune, IAR, Keil
ST STM32 (ARM Cortex-M0, ARM Cortex-M7, ARM Cortex-M3 and ARM Cortex-M4F), STR7 (ARM7), STR9 (ARM9) IAR, Atollic TrueStudio, GCC, Keil, Rowley CrossWorks
T
TI RM48, TMS570, ARM Cortex-M4F MSP432, MSP430, MSP430X, SimpleLink, Stellaris (ARM Cortex-M3, ARM Cortex-M4F) Rowley CrossWorks, IAR, GCC, Code Composer Studio
X
Xilinx Zynq, Zynq UltraScale+ MPSoC (64-bit ARM Cortex-A53 and 32-bit ARM Cortex-R5), Microblaze, PPC405 running on a Virtex4 FPGA, PPC440 running on a Virtex5 FPGA. GCC
Intel/x86 IA32 (32-bit flat memory model), Quark SoC X1000 (32-bit flat memory model), any x86 compatible running in Real mode only, plus a Win32 port. A port for the Linux Simulator is available as well. GCC, Visual Studio 2010 Express, MingW, Open Watcom, Borland, Paradigm
Tricore, MICO32, Blackfin, Jennic, eZ80, SuperH and others. Contributed Ports Contributed ports are provided "as is" and are not supported directly.
