FreeRTOS 202111.00 Release:
Symmetric Multi-Processing:
Co-routines
[More about co-routines...]
Co-Routine Priorities
Each co-routine is assigned a priority from 0 to ( configMAX_CO_ROUTINE_PRIORITIES - 1 ). configMAX_CO_ROUTINE_PRIORITIES is defined within FreeRTOSConfig.h and can be set on an application by application basis.
Low priority numbers denote low priority co-routines.
Co-routine priorities are only with respect to other co-routines. Tasks will always take priority over co-routines should you mix tasks and co-routines within the same application.
