FreeRTOS SMP:
Embedded World track keynote:
xTimerReset
 BaseType_t xTimerReset( TimerHandle_t xTimer,
                            TickType_t xBlockTime );
xTimerReset() re-starts a timer that was previously created using the xTimerCreate() API function. If the timer had already been started and was already in the active state, then xTimerReset() will cause the timer to re-evaluate its expiry time so that it is relative to when xTimerReset() was called. If the timer was in the dormant state then xTimerReset() has equivalent functionality to the xTimerStart() API function.
Resetting a timer ensures the timer is in the active state. If the timer is not stopped, deleted, or reset in the mean time, the callback function associated with the timer will get called 'n' ticks after xTimerReset() was called, where 'n' is the timers defined period.
It is valid to call xTimerReset() before the RTOS scheduler has been started, but when this is done the timer will not actually start until the RTOS scheduler is started, and the timers expiry time will be relative to when the RTOS scheduler is started, not relative to when xTimerReset() was called.
The configUSE_TIMERS configuration constant must be set to 1 for xTimerReset() to be available.
xTimer   The handle of the timer being reset/started/restarted.
xBlockTime   Specifies the time, in ticks, that the calling task should be held in the Blocked state to wait for the reset command to be successfully sent to the timer command queue, should the queue already be full when xTimerReset() was called. xBlockTime is ignored if xTimerReset() is called before the RTOS scheduler is started.
pdFAIL will be returned if the reset command could not be sent to the timer command queue even after xBlockTime ticks had passed. pdPASS will be returned if the command was successfully sent to the timer command queue. When the command is actually processed will depend on the priority of the timer service/daemon task relative to other tasks in the system, although the timers expiry time is relative to when xTimerReset() is actually called. The timer service/daemon task priority is set by the configTIMER_TASK_PRIORITY configuration constant.
/* When a key is pressed, an LCD back-light is switched on.  If 5 seconds pass
this case, the timer is a one-shot timer. */
TimerHandle_t xBacklightTimer = NULL;
parameter is not used. */
/* The key press event handler. */
void vKeyPressEventHandler( char cKey )
    key inactivity.  Wait 10 ticks for the command to be successfully sent
    if it cannot be sent immediately. */
    if( xTimerReset( xBacklightTimer, 10 ) != pdPASS )
        action here. */
void main( void )
long x;
    /* Create then start the one-shot timer that is responsible for turning
    the back-light off if no keys are pressed within a 5 second period. */
    xBacklightTimer = xTimerCreate
                  /* Just a text name, not used by the RTOS kernel. */
                  "BacklightTimer",
                  /* The timer period in ticks. */
                  ( 5000 / portTICK_PERIOD_MS),
                  /* The timer is a one-shot timer. */
                  pdFALSE,
                  /* The id is not used by the callback so can take any
                  value. */
                  0,
                  /* The callback function that switches the LCD back-light
                  off. */
    if( xBacklightTimer == NULL )
        /* Start the timer.  No block time is specified, and even if one was
        it would be ignored because the RTOS scheduler has not yet been
        started. */
        if( xTimerStart( xBacklightTimer, 0 ) != pdPASS )
            /* The timer could not be set into the Active state. */
     Create tasks here.
    /* Starting the RTOS scheduler will start the timer running as it has
    already been set into the active state. */
    vTaskStartScheduler();
    /* Should not reach here. */
    for( ;; );
