This quick example demonstrates the use of co-routines.
Creating a simple co-routine to flash an LED
The following code defines a very simple co-routine that does nothing but periodically flashes an LED.
void vFlashCoRoutine( CoRoutineHandle_t xHandle,
UBaseType_t uxIndex )
crSTART( xHandle );
for( ;; )
// Delay for a fixed period.
crDELAY( xHandle, 10 );
// Flash an LED.
vParTestToggleLED( 0 );
crEND();
Thats it!
Scheduling the co-routine
Co-routines are scheduled by repeated calls to vCoRoutineSchedule(). The best place to do this is from within the idle task by writing
an idle task hook. First ensure that configUSE_IDLE_HOOK is set to 1 within FreeRTOSConfig.h. Then write the idle task hook as:
Create the co-routine and start the RTOS scheduler
The co-routine can be created within main().
#include "task.h"
#include "croutine.h"
#define PRIORITY_0 0
void main( void )
// In this case the index is not used and is passed
// in as 0.
xCoRoutineCreate( vFlashCoRoutine, PRIORITY_0, 0 );
// NOTE: Tasks can also be created here!
// Start the RTOS scheduler.
vTaskStartScheduler();
Extending the example: Using the index parameter
Now assume that we want to create 8 such co-routines from the same function. Each co-routine will flash a different
LED at a different rate. The index parameter can be used to distinguish between the co-routines from within the
co-routine function itself.
This time we are going to create 8 co-routines and pass in a different index to each.
#include "task.h"
#define NUM_COROUTINES 8
void main( void )
int i;
for( i = 0; i < NUM_COROUTINES; i++ )
// This time i is passed in as the index.
xCoRoutineCreate( vFlashCoRoutine, PRIORITY_0, i );
The co-routine function is also extended so each uses a different LED and flash rate.
const int iFlashRates[ NUM_COROUTINES ] = { 10, 20, 30, 40, 50, 60, 70, 80 };
const int iLEDToFlash[ NUM_COROUTINES ] = { 0, 1, 2, 3, 4, 5, 6, 7 }
void vFlashCoRoutine( CoRoutineHandle_t xHandle, UBaseType_t uxIndex )
crSTART( xHandle );
for( ;; )
// Delay for a fixed period. uxIndex is used to index into
// the iFlashRates. As each co-routine was created with
// a different index value each will delay for a different
// period.
crDELAY( xHandle, iFlashRate[ uxIndex ] );
// Flash an LED. Again uxIndex is used as an array index,
// this time to locate the LED that should be toggled.
vParTestToggleLED( iLEDToFlash[ uxIndex ] );
crEND();
