FreeRTOS 202111.00 Release:
Symmetric Multi-Processing:
taskENTER_CRITICAL_FROM_ISR()
taskEXIT_CRITICAL_FROM_ISR()
[RTOS Kernel Control]
task. h
UBaseType_t taskENTER_CRITICAL_FROM_ISR( void );
void taskEXIT_CRITICAL_FROM_ISR( UBaseType_t uxSavedInterruptStatus );
Versions of taskENTER_CRITICAL() and taskEXIT_CRITICAL() that can be used in an interrupt service routine (ISR).
In an ISR critical sections are entered by calling taskENTER_CRITICAL_FROM_ISR(), and subsequently exited by calling taskEXIT_CRITICAL_FROM_ISR().
The taskENTER_CRITICAL_FROM_ISR() and taskEXIT_CRITICAL_FROM_ISR() macros provide a basic critical section implementation that works by simply disabling interrupts, either globally, or up to a specific interrupt priority level.
If the FreeRTOS port being used supports interrupt nesting then calling taskENTER_CRITICAL_FROM_ISR() will disable interrupts at and below the interrupt priority set by the configMAX_SYSCALL_INTERRUPT_PRIORITY (or configMAX_API_CALL_INTERRUPT_PRIORITY) kernel configuration constant, and leave all other interrupt priorities enabled. If the FreeRTOS port being used does not support interrupt nesting then taskENTER_CRITICAL_FROM_ISR() and taskEXIT_CRITICAL_FROM_ISR() will have no effect.
Calls to taskENTER_CRITICAL_FROM_ISR() and taskEXIT_CRITICAL_FROM_ISR() are designed to nest, but the semantics of how the macros are used is different to the taskENTER_CRITICAL() and taskEXIT_CRITICAL() equivalents.
Critical sections must be kept very short, otherwise they will adversely affect the response times of higher priority interrupts that would otherwise nest. Every call to taskENTER_CRITICAL_FROM_ISR() must be closely paired with a call to taskEXIT_CRITICAL_FROM_ISR().
uxSavedInterruptStatus taskEXIT_CRITICAL_FROM_ISR() takes uxSavedInterruptStatus as its only parameter. The value used as the uxSavedInterruptStatus parameter must be the value returned from the matching call to taskENTER_CRITICAL_FROM_ISR().
taskENTER_CRITICAL_FROM_ISR() does not take any parameters.
taskENTER_CRITICAL_FROM_ISR() returns the interrupt mask state as it was before the macro was called. The value returned by taskENTER_CRITICAL_FROM_ISR() must be used as the uxSavedInterruptStatus parameter in the matching call to taskEXIT_CRITICAL_FROM_ISR().
taskEXIT_CRITICAL_FROM_ISR() does not return a value.
/* A function called from an ISR. */
void vDemoFunction( void )
UBaseType_t uxSavedInterruptStatus;
    /* Enter the critical section.  In this example, this function is itself called from
    within a critical section, so entering this critical section will result in a nesting
    depth of 2. Save the value returned by taskENTER_CRITICAL_FROM_ISR() into a local
    stack variable so it can be passed into taskEXIT_CRITICAL_FROM_ISR(). */
    uxSavedInterruptStatus = taskENTER_CRITICAL_FROM_ISR();
    /* Exit the critical section.  In this example, this function is itself called from a
    critical section, so interrupts will have already been disabled before a value was
    stored in uxSavedInterruptStatus, and therefore passing uxSavedInterruptStatus into
    taskEXIT_CRITICAL_FROM_ISR() will not result in interrupts being re-enabled. */
    taskEXIT_CRITICAL_FROM_ISR( uxSavedInterruptStatus );
/* A task that calls vDemoFunction() from within an interrupt service routine. */
void vDemoISR( void )
    /* Call taskENTER_CRITICAL_FROM_ISR() to create a critical section, saving the
    returned value into a local stack variable. */
    /* Calls to taskENTER_CRITICAL_FROM_ISR() can be nested so it is safe to call a
    function that includes its own calls to taskENTER_CRITICAL_FROM_ISR() and
    vDemoFunction();
    critical section.  Assuming interrupts were enabled on entry to this ISR, the value
    saved in uxSavedInterruptStatus will result in interrupts being re-enabled.*/
