FreeRTOS LTS:
Renesas RZ/T RTOS Demo
Including FreeRTOS+CLI, Using IAR and GCC embedded compilers
Renesas RZ/T1 RSK used for the RTOS demo
This page documents a FreeRTOS demo application for the Renesas RZ/T embedded processor, which has an ARM Cortex-R4F core. Two projects are provided, allowing the demo to be built with with the IAR Embedded Workbench or GCC embedded development tools. The demo targets the Renesas RZT1 RSK (Renesas Starter Kit).
Both projects include build options that allow the creation of a simple blinky demo or a comprehensive demo, and use:
  • The FreeRTOS Cortex-R4F kernel port (the version for embedded processors that do not also include the ARM Generic Interrupt Controller, or GIC), which supports interrupt nesting.
  • Either the IAR Embedded Workbench or e2studio IDE (depending on the project file used)
  • The FreeRTOS+CLI command line interface.
  • The standard demo tasks - including the tasks that test interrupt nesting
IMPORTANT! Notes on using the RTOS Renesas RZ/T demo project
  3. Build Instructions (for both Embedded Workbench and e2studio)
  4. RTOS Configuration and Usage Details, in particular:
Also see the FAQ My application does not run, what could be wrong?
The FreeRTOS zip file contains source code for all the RTOS ports and all the RTOS demo applications. Only a small subset of these files are required by the Renesas RZ/T ARM Cortex-R4F demo. The Source Code Organization page describes the structure of the FreeRTOS zip file download, and provides information on creating a new RTOS project.
The e2studio Eclipse project file used to build the demo with GCC, and the IAR Embedded Workbench project file used to build the demo with the IAR compiler, are both located in the FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR directory.
The e2studio GCC and IAR projects build the same RTOS demo application, and both include files that are contained in the /FreeRTOS-Plus directory, so the projects will not build if the /FreeRTOS-Plus directory has been deleted or moved from its default location.
The Renesas RZ/T ARM Cortex-R4 Demo Application
Hardware and software set up
The demo documented on this page uses the UART to USB converter and LEDs built onto the RZT1 RSK, so no hardware setup is required.
The simply blinky example
  • The main_full() Function:
    The CLI is implemented using the FreeRTOS+CLI extensible command line interface, and uses the UART to USB converter connector (J8) at 19200 baud for its input and output. As always with FreeRTOS+CLI, type "help" to see a list of registered commands.
  • The "Reg Test" Tasks:
    The reg test tasks test the context switching mechanism by filling each embedded processor register with a known value, then continuously checking that each register maintains its expected value for the lifetime of the task.
  • The "Check" Task:
Build Instructions
Note that the IAR project references common files from both the /FreeRTOS-Plus and /FreeRTOS/Demo/Common directories, so the project will not compile if either directory has been deleted or moved.
  1. Open FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/RTOSDemo.eww from within the IAR Embedded Workbench IDE.
  3. Select "Build All" from the IDE's "Project" menu to build the RTOS demo.
  6. Select "Download and Debug" from the IDE's "Project" window to download the built executable to the ARM Cortex-R4F, and start a debug session.
Building and executing the demo application - e2studio
Note that the e2studio Eclipse project uses both virtual folders and links that reference files from both the /FreeRTOS-Plus and /FreeRTOS/Demo/Common directories. The [virtual] file structure viewed in the Eclipse project explorer will not match the [actual] file structure viewed on the disk, and the project will not built if either referenced directory is missing or has been moved.
  1. Open e2studio and either create a new workspace or select an existing workspace when prompted.
  3. In the Import dialog box, select "General->Existing Projects Into Workspace" then browse to and select the FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR directory. A project called "RTOSDemo" will be visible.
  6. Ensure the target hardware is connected to the host computer using an appropriate debug interface, for example, a J-Link.
  8. After the build completes, select "Debug Configurations..." from the IDE's "Debug" menu, and configure and run a debug configuration that is appropriate for your selected connection method. The clickable screenshots below show a configuration that is using a J-Link JTAG interface.
    Click images to enlarge
When an interrupt occurs, the RZ/T real time embedded processor hardware will vector directly to a peripheral specific interrupt handler, rather than to the ARM Cortex-R IRQ vector. Therefore, each interrupt handler installed by the application must include an assembly file wrapper that performs some house keeping, then branches to the FreeRTOS interrupt entry code. The FreeRTOS interrupt entry code manages interrupt entry, including interrupt nesting, before calling a standard C function in which the interrupting peripheral is serviced.
For the purpose of this example, assume the C portion of the interrupt handler is called InterruptHandler() - as shown below. A full example is provided after the sections that demonstrate how to write the assembly file wrappers:
void InterruptHandler( void )
/* Write the interrupt handler code here. */
The C portion of the interrupt handler - this is where the interrupting peripheral is serviced
For the purposes of this example, assume the assembly wrapper is called InterruptHandlerWrapper(). The wrapper must save a pointer to the C portion of the handler function into a variable called pxISRFunction, then branch to a function called FreeRTOS_IRQ_Handler (which is provided by the RTOS).
The syntax required to add the assembly file wrapper to each C interrupt handler function is dependent on the compiler used (IAR or GCC). Examples and further references are provided below.
Writing an assembly wrapper for an ISR: IAR
When using the IAR tools, the assembly wrapper must be implemented in an assembly file. A generic example is provided below. Further examples can be found in /FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/System/IAR/Interrupt_Entry_Stubs.asm.
SECTION intvec:CODE:ROOT(2)
ARM
/* Variables and functions from the RTOS port. */
EXTERN pxISRFunction
EXTERN FreeRTOS_IRQ_Handler
/* The C portion of the interrupt handler. */
EXTERN InterruptHandler
/* Functions implemented in this file. */
PUBLIC InterruptHandlerEntry
/* The implementation of InterruptHandlerEntry. */
InterruptHandlerEntry:
/* Save used registers (probably not necessary). */
PUSH {r0-r1}
/* Save the address of the C portion of this handler into pxISRFunction. */
LDR r0, =pxISRFunction
LDR R1, =InterruptHandler
STR R1, [r0]
/* Restore used registers. */
POP {r0-r1}
Branch to the RTOS IRQ handler. */
B FreeRTOS_IRQ_Handler
The assembly wrapper for the C interrupt handler function - IAR
Writing an assembly wrapper for an ISR: GCC
When using the GCC tools, the GCC inline assembler and the 'naked' function attribute can be used to include the assembly wrapper in a C file. A generic example is provided below. Further examples can be found in the /FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/FreeRTOS_tick_config.c, /FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/cg_src/r_cg_scifa_user.c and /FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/full_demo/IntQueueTimer.c source files.
#include "FreeRTOS.h"
/* The prototype for the function that implements the assembly file wrapper must
use the naked attribute - which prevents the compiler from adding any function
prologue or epilogue assembly code. */
void InterruptHandlerWrapper( void ) __attribute__((naked));
/* The implementation of InterruptHandlerEntry. This is a naked function and
must not include and C code! */
__asm volatile (
"PUSH {r0-r1} tn"
/* Save the address of the C portion of this handler in pxISRFunction. */
"LDR r0, =pxISRFunction tn"
"LDR r1, =InterruptHandler tn"
"STR r1, [r0] tn"
"POP {r0-r1} tn"
"B FreeRTOS_IRQ_Handler "
The assembly wrapper for the C interrupt handler function - GCC
Writing the C portion of an ISR: IAR and GCC
void InterruptHandler(void)
Dummy_ClearPendingInterrupt();
The C portion of an interrupt service routine
The RTOS Cortex-R port is a generic port that is tailored to specific embedded processor implementation using macros and callback functions. The RTOS tick interrupt is configured using the following two macros, which are defined in the FreeRTOSConfig.h file supplied with the RTOS demo application:
  1. configSETUP_TICK_INTERRUPT()
    This must call the function that configures a timer to generate the tick interrupt, and install FreeRTOS_Tick_Handler() as the timers interrupt service routine (via an assembly wrapper, as described above).
    In the provided demo application the macro is set to call vConfigureTickInterrupt(), which is defined in FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/FreeRTOS_tick_config.c, and configures the compare match timer 5 (CMT5) to generate the RTOS tick.
  2. configCLEAR_TICK_INTERRUPT()
    This must clear pending interrupts in whichever timer is used to generate the RTOS tick.
    In the provided demo application the macro is set to clear the interrupt in CMT5, as the RTOS tick interrupt is generated by CMT5.
Including the IRQ handling function
The RTOS Cortex-R port is a generic port that is tailored to a specific embedded processor implementation using macros and callback function. In the RZ/T RTOS port the generic IRQ handling code (the code that manages interrupt entry) calls vApplicationIRQHandler(), and vApplicationIRQHandler() must be provided by the application.
In the provided demo application vApplicationIRQHandler() is implemented in FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/FreeRTOS_tick_config.c, and replicated below:
/* The function called by the FreeRTOS IRQ handler, after it has managed
interrupt entry. This function creates a local copy of pxISRFunction before
re-enabling interrupts then calling the handler pointed to by pxISRFunction.
pxISRFunction is set by the assembly wrapper added to each interrupt handler. */
void vApplicationIRQHandler( void )
ISRFunction_t pxISRToCall = pxISRFunction;
portENABLE_INTERRUPTS();
/* Call the installed ISR. */
pxISRToCall();
The implementation of vApplicationIRQHandler() for the RZ/T RTOS port
FreeRTOS ARM Cortex-R4F port demo application specific configuration
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_R4F_RZ_T_GCC_IAR/src/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application.
FreeRTOS requires exclusive use of the SVC interrupt.
Source/Portable/MemMang/heap_4.c is included in the ARM Cortex-R4 RTOS demo application project to provide the memory allocation required by the RTOS kernel. Please refer to the Memory Management section of the API documentation for full information.
