LPC1768 ARM Cortex-M3 IAR Demo
[Embedded Ethernet Examples]
This page presents an IAR web server and USB demo that is pre-configured to run on the evaluation board that comes in the KSK-LPC1768-PL Kickstart Kit. The evaluation board is fitted with an LPC1768 Cortex-M3 microcontroller from NXP.
The demo uses:
  • The FreeRTOS IAR ARM Cortex-M3 port.
  • The IAR Embedded Workbench V5.40.
The IAR Embedded Workbench workspace for the LPC1768 demo is called RTOSDemo.eww and can be found in the FreeRTOS/Demo/CORTEX_LPC1768_IAR directory.
web server configuration
Connect the evaluation board to a computer running a web browser either directly using a point to point (crossover) cable, or via a Ethernet switch using a standard Ethernet cable.
The IP address used by the demo is set by the constants configIP_ADDR0 to configIP_ADDR3 within the file FreeRTOS/Demo/CORTEX_LPC1768_IAR/FreeRTOSConfig.h. The MAC address and net mask are configured within the same header file.
The IP addresses used by the web browser computer and the evaluation board must be compatible. This can be ensured by making the first three octets of both IP addresses identical. For example, if the web browser computer uses IP address 192.168.100.1, then the development board can be given any address in the range 192.168.100.2 to 192.168.100.254 (barring any addresses already present on the network).
  1. Open FreeRTOS/Demo/CORTEX_LPC1768_IAR from within the Embedded Workbench IDE.
  2. Kickstart versions of Embedded Workbench can only be used with compiled binary images of 32K bytes and under - it is necessary to set the compiler optimisation to 'medium' prior to compilation if the Kickstart edition is being used.
  3. Connect the evaluation board to the host computer using a J-Link USB JTAG interface.
  4. Select "Download and Debug" from the "Project" menu - the demo application should build with no errors or warnings before being programmed into the LPC1768 Flash memory. The debugger will break at the start of main().
The demo application creates 34 tasks before starting the RTOS scheduler. The tasks consist primarily of the standard demo tasks (see the demo application section for details of the individual tasks). They exist to demonstrate how the FreeRTOS API can be used and test the FreeRTOS port only, and have no other useful purpose.
  • uIP task
  • USB task
  • User LED 1 is controlled by a basic 'flash' task that simply toggles the LED once per second.
  • The USB device port of the evaluation board will enumerate as a CDC class device. To use the USB port (assuming a Windows host computer):
    1. Connect the LPC1768 to your host computer using the USB device port of the evaluation board (ensuring the jumpers are set correctly for device operation, see the underside of the board for jumper settings).
    2. The host computer should recognise the new USB connection and prompt for the location of a suitable .inf file. Select the option to manually select the .inf file location, then browse to usbser.inf which is located in the FreeRTOS/Demo/CORTEX_LPC1768_IAR directory. Assuming usbser.sys is available on your host computer the CDC device will be assigned a COM port number. The Windows Device Manager can be used to ascertain the actual number assigned.
Note that the LCD is not used because the LCD driver is only permitted to be used with the Keil compiler.
Served Web Pages
The served IO page
The IO page provides a simple interface that permits data to be sent to an LED. The check box permits the state of the user LED 2 to be both set and queried. Changes are sent to the target hardware by clicking the "Update IO" button.
Configuration items specific to these demos are contained in FreeRTOS/Demo/CORTEX_LPC1768_IAR/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
Unlike most ports, interrupt service routines that cause a context switch have no special requirements and can be written as per the compiler documentation. The macro portEND_SWITCHING_ISR() can be used to request a context switch from within an ISR. An example interrupt service routine called vEMAC_ISR() is provided in FreeRTOS/Demo/CORTEX_LPC1768_IAR/webserver/emac.c. This should be used as a reference example.
Set the definition configUSE_PREEMPTION within FreeRTOS/Demo/CORTEX_LPC1768_IAR/FreeRTOSConfig.h to 1 to use pre-emption or 0 to use co-operative.
