FreeRTOS LTS:
Using IAR EWARM and Keil MDK development tools
Infineon XMC4000 Hexagon Development Kit CPU board
This page documents a demo application that targets the Infineon XMC4000 Hexagon Development Kit CPU board, which is fitted with an XMC4500 microcontroller. Build projects are provided for both the IAR Embedded Workbench and the Keil uVision development tools.
The FreeRTOS ARM Cortex-M4F port supports a full interrupt nesting model, and never completely disable interrupts. The port can only be used with the ARM Cortex-M4's hardware floating point unit turned on, and with the IAR or Keil project settings configured to generate floating point instructions. The demos described on this page are supplied pre-configured with these required settings. Cortex-M4 devices that don't include a floating point unit should not use the ARM Cortex-M4F port, but instead use the FreeRTOS ARM Cortex-M3 port layer.
Using a compile time option (described below), the projects can be configured to create either a basic blinky style demo, or a more comprehensive test and demo application that includes tasks that exercise the interrupt nesting behaviour.
Note that, if the Keil project is selected, Keil MDK version 4.2.2 or above is required, to which (at the time of writing) a patch needs to be supplied to provide integrated XMC4000 support. The no_allow_fpreg_for_nonfpdata compiler option must also be used, again, the demo supplied is pre-configured with this setting.
IMPORTANT! Notes on using the FreeRTOS IAR and Keil XMC4000 demo projects
Please read all the following points before using these RTOS projects
The FreeRTOS zip file download contains source code for all the FreeRTOS ports, and every demo application project. It therefore contains many more files than are required to build and run the Infineon XMC4500 demo. See the Source Code Organization section for a description of the downloaded files, and information on creating a new project.
The IAR Embedded Workbench for ARM demo project workspace is called RTOSDemo.eww, and is located in the FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_IAR directory of the official FreeRTOS .zip file download.
The Keil uVision demo project is called RTOSDemo.uvproj, and is located in the FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_Keil directory of the official FreeRTOS .zip file download.
Both the IAR and Keil RTOSDemo projects provide two configurations. They can be configured as a simple blinky style project, or a more comprehensive test and demo application. The mainCREATE_SIMPLE_BLINKY_DEMO_ONLY definition, located at the top of the respective main.c files, is used to switch between the two at compile time.
  • Software timers.
  • Semaphores.
  • Mutexes.
  • Queues.
A 'check' software timer is created that periodically inspects the standard demo tasks, and register test tasks, to ensure all the tasks are functioning as expected. The check software timer's callback function toggles the single user LED on the XMC4500 Hexagon development kit CPU board. This gives visual feedback of the system health. If the LED is toggling every 3 seconds, then the check software timer has not discovered any problems. If the LED is toggling every 200 milliseconds, then the check software timer has discovered a problem in one or more tasks.
  1. Set the mainCREATE_SIMPLE_BLINKY_DEMO_ONLY constant to generate the required demo functionality, as noted above.
  2. Ensure the target hardware is connected to the host computer using a suitable interface. The IAR project was created and tested using a J-Link. The Keil project was created and testing using a ULINK ME.
  3. Optionally open the RTOSDemo.eww IAR workspace from within the Embedded Workbench IDE, or the RTOSDemo.uvproj project from within the Keil uVision IDE.
  4. Select "Build" or "Make" from the IDE's "Project" menu (or press F7). The project should build without any warnings or errors.
  5. After the project has built, press CTRL+D if using IAR, or CTRL+F5 is using Keil to program the microcontroller's flash memory, and start a debug session. The debugger will then start running and break on entry to the main() function.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_IAR/FreeRTOSConfig.h or FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_Keil/FreeRTOSConfig.h for the IAR and Keil projects respectively. The constants defined in this file can be edited to suit your application. In particular -
