Support > FAQ > GitHub Repository Structure & Versioning
Homepage | FAQ
FreeRTOS FAQ - GitHub Repository Structure & Versioning
How are FreeRTOS Git repositories structured?
How are FreeRTOS libraries versioned?
Which library packages are available?
How do I obtain and use individual FreeRTOS libraries?
How do I obtain a FreeRTOS distribution package?
There are two types of repositories, single library repositories and package repositories. Each single library
repository contains the source code for one library without any build projects or examples. Package repositories
contain multiple libraries, and may contain pre-configured projects that demonstrate the library’s use.
While package repositories contain multiple libraries, they do not contain copies of those libraries. Instead,
package repositories reference the libraries they contain as
git sub-modules. Using sub-modules ensures
there is a single source of truth for each individual library.
The individual library git repositories are split between two GitHub organisations. Repositories containing
FreeRTOS specific libraries (such as FreeRTOS+TCP) or generic libraries (such as coreMQTT, which is cloud
agnostic because it works with any MQTT broker) are in the FreeRTOS
GitHub organisation. Repositories containing AWS IoT specific libraries (such as the AWS IoT over-the-air
update client) are in the AWS GitHub organisation.
The following diagram demonstrates the structure.
GitHub Repository Structure - click to enlarge
Individual libraries use x.y.z style version numbers, similar to semantic versioning.
x is the major version number, y the minor version number, and (from 2022) z a patch number. Prior to 2022 z was a point release number, meaning patches
to the first LTS libraries required a separate patch number of the form "x.y.z LTS Patch 2".
Library packages use yyyymm.x style date stamp version numbers. yyyy is the year, mm the month, and x an optional
sequence number showing the release order within the month (or, in the case of the LTS package, x is a sequential
patch number for that LTS release). The individual libraries contained in a package are whatever the latest version
of that library was on that date (or, in the case of the LTS package, the latest patch version of the LTS libraries
originally released as an LTS version on that date).
There are four library packages.
Primary FreeRTOS distribution (from the FreeRTOS GitHub organization):
This contains many pre-configured projects that demonstrate the FreeRTOS kernel running on different processors
and using different compilers, as well as projects that demonstrate other FreeRTOS libraries (such as
FreeRTOS+TCP) running in emulated environments.
FreeRTOS AWS IoT reference integration distribution (from the AWS GitHub organization):
This contains many pre-configured projects that demonstrate the integration of FreeRTOS and AWS libraries running
on different processors (and in the Windows simulator), using different compilers, and being used to connect to AWS IoT services.
AWS IoT Embedded C SDK for devices:
Similar to the FreeRTOS AWS IoT reference integrations, but demonstrating the libraries running on a POSIX
operating system instead of FreeRTOS.
LTS versions of FreeRTOS libraries:
This is for reference and convenience only. It contains just the
Long Term Support (LTS) versions of the FreeRTOS
libraries, with no example projects.
The recommended way to use individual libraries in your application is to sub-module them directly from GitHub into your application
project. Alternatively, you can copy an individual library into your application by downloading a zip file of the
library from the GitHub repository's Releases area. The following table contains links to individual libraries. The package downloads contain examples.
Here are instructions for each package. Note, if using git to obtain a library package then additionally follow the repository cloning instructions in the package’s readme.md file to ensure you also initialize and synch sub-module references:
Primary FreeRTOS distribution:
Most people use the download button on the FreeRTOS.org website
to obtain a zip file. The package distribution is also available from GitHub as either a
git repository or
zip file.
FreeRTOS AWS IoT reference integration distribution:
This package distribution is available from the AWS account in GitHub, but is large. The Online Configuration
Wizard (OCW, available through the
AWS console) and AWS partner device catalog
both provide more convenient distributions.
This package is available from GitHub as either a
git repository or
zip file.
Similar to the primary FreeRTOS distribution, most people use the
download button on the FreeRTOS.org website to obtain a zip
file. The distribution is also available from GitHub as either a
git repository or
zip file.
