Application Protocols
Application Protocol libraries provide connectivity for building microcontroller-based IoT devices. The 'core' branded application protocols are 'standalone' in that they do not have any dependencies outside of the C library. They use a simple transport interface definition to ensure they are not dependent on the underlying TCP/IP stack.
coreMQTT
A lightweight pub/sub protocol for IoT use cases.
Source code is now available in coreMQTT github repository.
Learn More
coreMQTT Agent
A thread safe MQTT library using coreMQTT for IoT use cases.
Source code is now available in coreMQTT-Agent github respository.
Learn More
coreHTTP
A lightweight request and response messaging protocol for IoT use cases.
Source code is now available in coreHTTP github respository.
Learn More
coreSNTP
The coreSNTP library provides a client for the Simple Network Time Protocol (SNTP) to allow devices
to synchronize their system clocks with time servers. This library implements the SNTPv4 specification defined in
RFC 4330.
Source code is now available in coreSNTP github repository.
Learn More
Transport Interface
Interface for sending and receiving data that is not dependent on the underlying TCP/IP stack
Learn More
coreJSON
A parser that strictly enforces the ECMA-404 JSON standard.
Source code is now available in coreJSON github repository.
Learn More
corePKCS #11
A cryptographic API layer (OASIS standard) that abstracts key storage, get/set properties for cryptographic objects, and session semantics.
Source code is now available in corePKCS11 github repository.
Learn More
