FreeRTOS LTS:
Tensilica Xtensa Customizable Processors RTOS Demo
Using Xtensa Xplorer IDE
This page documents the demo application that targets the Tensilica Xtensa Customizable Processors. The project targets the Xtensa Simulator, and builds using the Xtensa Xplorer IDE and the XCC compiler. The project can be compiled to create either a simple blinky demo, or a comprehensive test and demo application.
Xtensa Xplorer IDE for the RTOS project
Screen shot of the Xtensa Xplorer IDE
IMPORTANT! Notes on using the Tensilica Xtensa Customizable Processors Demo
The FreeRTOS download contains the source code for every FreeRTOS port and all the demo applications. It therefore contains a lot more files than are required by the Tensilica demos. See the Source Code Organization section of this website for a description of the downloaded files.
The Xtensa Xplorer project is located in the /FreeRTOS/Demo/Tensilica_Simulator_Xplorer_XCC directory and has the usual Eclipse project name .project.
Building and Running the Tensilica Xtensa Customizable Processors RTOS Application
The RTOS demo project can be configured to build either a simple blinky demo, or a comprehensive test and demo application. The constant mainCREATE_SIMPLE_BLINKY_DEMO_ONLY, which is defined at the top of main.c file, is used to switch between the two.
  • The simple blinky demo is created if mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1.
  • The comprehensive demo is created if mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0.
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1 then main() calls main_blinky(). main_blinky() creates a very simple demo as follows:
    main_blinky() creates one queue, one software timer, and two tasks. It then starts the RTOS scheduler.
    The queue send task is implemented by the prvQueueSendTask() function in main_blinky.c file. It uses vTaskDelayUntil() to send the value 100 to the queue every 200 milliseconds.
  • The Queue Send Software Timer:
    The timer is an auto-reload timer with a period of two seconds. The timer's callback function writes the value 200 to the queue. The callback function is implemented by prvQueueSendTimerCallback() within main_blinky.c file.
    The queue receive task is implemented by prvQueueReceiveTask() in main_blinky.c file. It waits for data to arrive on the queue. When data is received, the task checks the value of the data, then outputs a message to indicate if the data came from the queue send task or the queue send software timer.
    Note this is the only task that outputs a message, so no attempt is made to make the printf function thread safe. Be careful to not use the printf function in more than one tasks.
The expected behavior is as follows:
  • The queue send task writes to the queue every 200ms, so every 200ms the queue receive task will output a message indicating that data was received on the queue from the queue send task.
  • The queue send software timer has a period of two seconds, so every two seconds the queue receive task will output a message indicating that data was received on the queue from the queue send software timer.
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0 then main() calls main_full(). main_full() creates a comprehensive test and demo application that demonstrates, among other things: The created tasks are from the set of standard demo tasks. Standard demo tasks are used by all FreeRTOS port demo applications and have no specific functionality. They are used to demonstrate how to use the FreeRTOS API, and to test the RTOS port.
A 'check' task is created to periodically inspect the standard demo tasks in order to ensure all the tasks are functioning as expected. If no error is detected, the check task periodically outputs "No errors", the current simulated tick time, free heap size and the minimum free heap size so far. If an error is discovered in the execution of a task then the check task will output an appropriate error message.
Interrupt queue tests (file IntQueue.c) exercise interrupt nesting and are observed to interfere with the proper functioning of other tests on the Simulator. Therefore, the mainENABLE_INT_QUEUE_TESTS macro is provided in the file main_full.c to choose whether to enable interrupt queue tests or all other tests.
  • When mainENABLE_INT_QUEUE_TESTS is set to 1, interrupt queue tests are enabled and every other test is disabled.
  • When mainENABLE_INT_QUEUE_TESTS is set to 0, interrupt queue tests are disabled and every other test is enabled.
Building with Xtensa Xplorer IDE
  1. Start the Xtensa Xplorer IDE, and either create a new or select an existing workspace when prompted.
  2. Select "Import" from the IDE's "File" menu. The dialogue box shown below will appear. Select "General-->Existing Projects into Workspace", as shown below:
    Xtensa Xplorer IDE File Import Dialog
  3. In the next dialogue box, select /FreeRTOS/Demo/Tensilica_Simulator_Xplorer_XCC as the root directory. Make sure the RTOSDemo project is checked in the "Projects" area, and that the Copy Projects Into Workspace box is not checked, before clicking the Finish button (see the image below for the correct check box states).
    Selecting the RTOS source code when importing into Xtensa Xplorer IDE
  4. Select "RTOSDemo" from the Active Project dropdown, as shown below (click to enlarge):
    Xtensa Xplorer IDE Select Active Project
  5. Select "Build Active" from the Build dropdown (or press Ctrl+Alt+B), as shown below (click to enlarge):
    Xtensa Xplorer IDE Build
    Build Active Project
  6. Select "Debug" from the Debug dropdown to start a debug session, as shown below (click to enlarge):
    Xtensa Xplorer IDE Debug
    Debug Active Project
  7. Select "Simulator Console" from the Console dropdown to see the output from the demo, as shown below (click to enlarge):
    Xtensa Xplorer IDE Simulator Console
    Simulator Console
Interrupt service routines that cause a context switch have no special requirements and can be written as per the compiler documentation. An example is provided below which shows the use of the macro portYIELD_FROM_ISR to request a context switch from within an interrupt service routine. See the file FreeRTOS/Demo/Tensilica_Simulator_Xplorer_XCC/IntQueueTimer.c for a full example.
void Dummy_IRQHandler( void *arg )
    ( void ) arg; /* Parameter not used. */
Each port #defines 'BaseType_t' to equal the most efficient data type for that processor. This port defines BaseType_t to be of type int.
Source/Portable/MemMang/heap_4.c is included in the demo application project to provide the memory allocation required by the RTOS kernel. Please refer to the Memory Management section of the API documentation for full information.
Note that vPortEndScheduler() has not been implemented
