FreeRTOS LTS:
FreeRTOS for Renesas RX71M (RXv2)
Renesas RX71M RSK
This page documents the RTOS demo applications that targets the Renesas RX71M microcontroller, which has an RXv2 core.
Three projects are provided:
All three projects include build options that allow the creation of a simple blinky demo or a comprehensive demo, and target the RX71M RSK (Renesas Start Kit) evaluation board. The comprehensive demo includes a command line interface implemented with FreeRTOS+CLI.
IMPORTANT! Notes on using the RX71M RTOS demo projects
The FreeRTOS download contains the source code for all the RTOS ports, so contains lots more files than are required by the RX71M projects. See the Source Code Organization section of this website for more information.
The IAR project is called RTOSDemo.eww, and is located in the /FreeRTOS/Demo/RX700_RX71M_RSK_GCC_e2studio_IAR directory.
The e2studio projects have the usual Eclipse project name .project. The project that uses the GCC compiler is also located in the /FreeRTOS/Demo/RX700_RX71M_RSK_GCC_e2studio_IAR directory, and the project that uses the Renesas compiler is located in the /FreeRTOS/Demo/RX700_RX71M_RSK_Renesas_e2studio directory. These are the directories that must be selected when importing the projects into the e2studio Eclipse workspace.
Building and Running the Renesas RX71M RTOS Demo
    Importing the RX71M project into the e2studio Eclipse IDE
  3. In the next dialogue box, select /FreeRTOS/Demo/RX700_RX71M_RSK_GCC_e2studio_IAR as the root directory if you are using the GCC compiler, or /FreeRTOS/Demo/RX700_RX71M_RSK_Renesas_e2studio if you are using the Renesas compiler.
  7. Ensure the E1 debug adapter (which comes with the RSK starter kit) is connected between the RX71M RSK board and the computer running e2studio. If you configure the launch configurations as per the images below then there is no need for a separate power supply.
    Click images to enlarge
The simply blinky example
  • The main_full() Function:
    The CLI is implemented using the FreeRTOS+CLI extensible command line interface, and uses SCI1 at 19200 baud for its input and output. As always with FreeRTOS+CLI, type "help" to see a list of registered commands.
  • The "Reg Test" Tasks:
  • The "Check" Task:
RX71M RTOS port specific configuration
Configuration items specific to this demo are contained in /FreeRTOS/Demo/RX700_RX71M_RSK_GCC_e2studio_IAR/src/FreeRTOSConfig.h for the IAR and GCC projects, and /FreeRTOS/Demo/RX700_RX71M_RSK_Renesas_e2studio/src/FreeRTOSConfig.h for the Renesas compiler project. The constants defined in these files can be edited to suit your application. In particular -
    This defines the interrupt priority used by the RTOS kernel for the RTOS tick timer and software interrupts. This should always be set to the lowest interrupt priority, which is 1 for the RX71M. See the configuration pages for more information.
/* Function definition. */
    function. */
    __enable_interrupt();
    function. */
/* The function prototype uses the interrupt attribute.  The function
    __asm volatile( "SETPSW	I" );
    function. */
It is suggested that a compare match timer is used to generate the tick interrupt, and an example implementation of vApplicationSetupTimerInterrupt() that uses compare match timer 0 is included in main.c within each RX700 demo application.
Source/Portable/MemMang/heap_4.c is included in the RX71M demo application project to provide the memory allocation required by the RTOS kernel. Please refer to the Memory Management section of the API documentation for full information.
