FreeRTOS LTS:
FreeRTOS for Renesas RX64M
Supporting Renesas and GCC compilers with e2studio
Renesas RX64M RSK
This page documents the RTOS demo applications that targets the Renesas RX64M family of microcontrollers, which contain the RXv2 core.
Two e2studio projects are provided, one that is pre-configured to use the Renesas compiler, and one that is pre-configured to use the GCC compiler.
Both RTOS projects target the RX64M RSK (Renesas Start Kit) evaluation board.
IMPORTANT! Notes on using the RX64M e2studio demo projects
The FreeRTOS download contains the source code for all the FreeRTOS ports, so contains many more files than are needed by the RX64M e2studio projects. See the Source Code Organization section for a description of the downloaded files and information on creating a new project.
The e2studio projects have the usual Eclipse project name .project. The project that uses the Renesas compiler is located in the FreeRTOS/Demo/RX600_RX64M_RSK_Renesas_e2studio directory. The project that uses the GCC compiler is located in the FreeRTOS/Demo/RX600_RX64M_RSK_GCC_e2studio directory. These are the directories that must be selected when importing the projects into the Eclipse workspace.
Building and Running the Renesas RX64M Demo Application
The RTOS demo projects can be configured to build either a simple blinky project, or a comprehensive test and demo application. The constant mainCREATE_SIMPLE_BLINKY_DEMO_ONLY, which is defined at the top of main.c, is used to switch between the two. The comprehensive demo is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0. The simple demo is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1.
The demos use the LEDs built onto the RSK development board, so no hardware set up is required.
Building with e2studio
Note: Some of the source files built by the e2studio projects are included in the project using a project relative path, so the project will fail to build if the FreeRTOS directory structure has been altered from that found in the .zip file.
  1. Start the e2studio Eclipse IDE and either create a new or select an existing workspace when prompted.
    Importing the RX64M project into the e2studio Eclipse IDE
  3. In the next dialogue box, select FreeRTOS/Demo/RX600_RX64M_RSK_Renesas_e2studio as the root directory if you are using the Renesas compiler, or FreeRTOS/Demo/RX600_RX64M_RSK_GCC_e2studio if you are using the GCC compiler. Make sure the RTOSDemo project is checked in the "Projects" area, and that the Copy Projects Into Workspace box is not checked, before clicking the Finish button (see the image below for the correct check box states).
  4. Open main.c and locate the mainCREATE_SIMPLE_BLINKY_DEMO_ONLY definition, which is near the top of the file. Set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to 1 to build the simply blinky style (starter) project. Set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to 0 to build the comprehensive test and demo application.
  5. Select "Build All" from the e2studio Eclipse "Project" menu to build the demo project, and wait for the build to complete.
  6. Ensure the E1 debug adapter (which comes with the RSK starter kit) is connected between the RX64M RSK hardware and the host computer. If you configure the launch configurations as per the images below then there is no need to supply any external power.
  7. Select "Debug Configurations" from the Eclipse "Run" menu to configure a launch configuration that can be used to program the microcontroller flash memory and start a debug session. Configure the debug launch configuration as shown in the images below.
    Click images to enlarge
The simply blinky example
The simple blinky example is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1. mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is defined in main.c
main() calls main_blinky():
    main_blinky() creates an RTOS queue, a queue send task, and a queue receive task, before starting the scheduler.
The comprehensive example is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0. mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is defined in main.c.
main() calls main_full():
  • The main_full() Function:
    main_full() creates a set of standard demo tasks, some application specific test tasks, and a pseudo randomiser task, before starting the scheduler. The pseudo randomiser task is just used to ensure some variation is added to the sequence in which the test tasks execute, and in so doing, improve the test coverage.
  • The "Reg Test" Tasks:
  • The "Check" Task:
    The "Check" task monitors the status of all the other tasks in the system, looking for a task either stalling or reporting an error. It toggles LED 3 each time it is called.
    If the LED is toggling every three seconds then the check task has not detected any stalled tasks or received any error reports. If the LED is toggling every 200ms then at least one error has been found.
  • The Standard Flash Tasks:
    LED 0, LED 1, and LED 2 are controlled by the standard demo flash tasks. Each LED will toggle with a fixed but unique frequency.
RX64M RTOS port specific configuration
Configuration items specific to this demo are contained in FreeRTOS/Demo/RX600_RX64M_RSK_Renesas_e2studio/Source/FreeRTOSConfig.h or FreeRTOS/Demo/RX600_RX64M_RSK_GCC_e2studio/src/FreeRTOSConfig.h for the Renesas compiler and GCC compiler projects respectively. The constants defined in these files can be edited to suit your application. In particular -
    This defines the interrupt priority used by the RTOS kernel for the timer and software interrupts. This should always be set to the lowest interrupt priority, which is 1 for the RX64M. See the configuration pages for more information.
The RX64M port layer #defines 'BaseType_t' to 'long'.
Interrupts can be written using the standard compiler syntax. Examples for both the Renesas and GCC compilers are provided below.
/* Function definition. */
    /* xSemaphoreGiveFromISR() is an interrupt safe FreeRTOS function.  It is
    assumed the semaphore has already been created.  If giving the semaphore
    unblocks a task, and the task that is unblocked has a priority above the
    parameter will get set to pdTRUE inside the xSemaphoreGiveFromISR()
    function. */
    xSemaphoreGiveFromISR( xSemaphore, &lHigherPriorityTaskWoken );
/* The function prototype uses the interrupt attribute. */
    __asm volatile( "SETPSW	I" );
    function. */
It is suggested that a compare match timer is used to generate the tick interrupt, and an example implementation of vApplicationSetupTimerInterrupt() that uses compare match timer 0 is included in main.c within this demo application.
Source/Portable/MemMang/heap_4.c is included in the RX64M demo application project to provide the memory allocation required by the RTOS kernel. Please refer to the Memory Management section of the API documentation for full information.
