FreeRTOS LTS:
Spansion (was Fujitsu) MB91460 demo
This page presents the FreeRTOS demo application for the 32bit Spansion MB91460 series RTOS port.
The demo is pre-configured to run on the SK-91F467-FLEXRAY starter kit from Spansion, and uses the Softune compiler, debugger and IDE - which come on the kit CD. The starter kit is fitted with a MB91467D MCU.
IMPORTANT! Notes on using the Spansion MB91460 Demo
The Softune workspace for the MB91460 demo is called 91467d_FreeRTOS.wsp and can be located in the Demo/MB91460_Softune directory.
Demo application setup
The starter kit jumpers must be set correctly for successful RS232 communication with the Softune IDE. The exact jumper settings required depends on your individual set up. Please refer to the starter kit manual for more information.
The demo application includes an interrupt driven UART test where one task transmits characters that are then received by another task. For correct operation of this functionality a loopback connector must be fitted to the UART 2 (X1) connector of the SK-91F467-FLEXRAY board (pins 2 and 3 must be connected together on the 9Way connector).
The demo uses the LEDs that are built onto the starter kit so no further specific hardware setup is required.
Building the demo application
  1. Open the Demo/MB91460_Softune/91467d_FreeRTOS.wsp workspace from within the Softune IDE.
  2. Select 'Build' from the IDE Project menu - the demo application should compile with no errors or warnings.
Starting a debug session
The instructions provided on this page utilise the Spansion debug monitor - which should already be programmed into the starter kit external Flash memory. If you have erased or overwritten the Flash memory then you will first need to restore the debug monitor. Instructions for doing this are provided in the starter kit manual.
To start the debug monitor:
  1. Locate S5 on the starter kit board - this is a bank of 5 micro switches. Ensure switch 1 is in the On position, and the remaining 4 switches are in the Off position.
  2. Power up or reset the starter kit. If LEDs D2, D4 and D8 are illuminated then the debug monitor is ready to receive the demo application download.
To download the demo application:
  1. Ensure the debug monitor is running as described above.
  2. Connect the starter kit supplied RS232 cable between port UART 4 (X4) on the starter kit and your host computer.
  3. Select 'Setup Project' from the Softune 'Project' menu to bring up the project settings dialogue box.
  4. In the project settings dialogue box, select the 'Debug' tab, 'Setup' category, and ensure the selected setup name is correct for you host computer. The image below demonstrates the setup used to communicate with the debug monitor using COM1 at 57K6 baud.
    Setting the method of communicating with the Spansion debug monitor.
  5. Select 'Start Debug' from the Softune 'Debug' menu. The RTOS demo application will be downloaded to the starter kit RAM and execute up to the start of main().
Controlling a debug session:
  1. Softune provides the expected step into, step over, watchpoint, breakpoint, etc. debugger functionality.
  2. The Softune IDE cannot be used to pause a program that is free running on the starter kit hardware. An application that is free running can be interrupted by pressing button INT 0 (SW2) on the starter kit board - this will pause the program execution and return control to the Spansion debug monitor.
The demo application creates 8 co-routines, 44 persistent tasks, and periodically dynamically creates and destroys another 2 tasks. These tasks consist predominantly of the standard demo application tasks (see the demo application section for details of the individual tasks).
  • Register test tasks
    This is a set of two tasks, each of which fill the MCU registers with known values, then immediately check that the registers contain the expected (written) value - an unexpected value being indicative of an error in the RTOS context switch mechanism. Each task uses different values, and as low priority tasks will regularly get interrupted.
  • Check task
  • The trace task
    The trace task is a user interactive task that writes execution trace and task state information to UART 5. To view the menu and provided information connect UART 5 (X8) to a terminal program (such as Hyperterminal) on your host PC. 9600 baud is used.
  • The 'check' function will toggle LED D8 every 3 seconds.
  • The trace task will send menu options to a terminal program via UART 5.
  • LEDs D1, D2 and D3 are under the control of the standard 'flash' tasks. Each will toggle at a fixed but different frequency, with LED D1 being the fastest and LED D3 being the slowest.
  • LEDs D9 to D16 are under the control of the 'flash' co-routines. Again each will toggle at a fixed but different frequency.
  • LED D5 is under control of the 'ComTest' Tx task. It will toggle each time a character is transmitted.
  • LED D6 is under control of the 'ComTest' Rx task. It will toggle each time a character is received.
Resources used by the RTOS
The RTOS yield function uses software interrupt 64 (0x40).
Watchdog
The settings within Demo/MB91460_Softune/SRC/watchdog/watchdog.h allow the selection of the method to use.
Configuration items specific to this demo are contained in Demo/MB91460_Softune/Src/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
Each port #defines 'BaseType_t' to equal the most efficient data type for that processor. This port defines BaseType_t to be of type long (32 bits).
Unlike most ports, interrupt service routines that cause a context switch have no special requirements and can be written as per the compiler documentation. The macro portYIELD_FROM_ISR() can be used to request a context switch from within an ISR. See Demo/MB91460_Softune/Src/serial/serial.c for an example.
Set the definition configUSE_PREEMPTION within Demo/MB91460_Softune/Src/FreeRTOSConfig.h to 1 to use pre-emption or 0 to use co-operative.
Serial driver
