FreeRTOS LTS:
FreeRTOS Spansion (was Fujitsu) 16FX demo
This page presents the FreeRTOS demo application for the Spansion MB96340 series RTOS port.
The demo is pre-configured to run on the SK-16FX-EUROScope starterkit from Spansion. The Softune compiler and IDE, and the EUROScope Lite debugger are used - both of which are included within the starterkit.
IMPORTANT! Notes on using the Spansion (was Fujitsu) 16FX Demo
The Softune workspace for the 16FX demo is called 96340_FreeRTOS_96348hs.wsp and can be located in the Demo/MB96340_Softune directory.
Demo application setup
The demo application includes an interrupt driven UART test where one task transmits characters that are then received by another task. For correct operation of this functionality a loopback connector must be fitted to the X4 connector of the SK-16FX-EUROScope board (pins 2 and 3 must be connected together on the 9Way connector).
You can power the starter kit through its USB port, and use the same USB port as a virtual COM port. You will be prompted to install USB drivers when connecting the starter kit via a USB cable for the first time. The required drivers are provided on the starter kit CD.
No further specific hardware setup is required.
Building the application, programming the Flash memory, and debugging are all performed using separate programs - these are Softune itself, the Spansion Flash MCU programmer, and EUROScope lite respectively. Installation executables for all three are provided on the starter kit CD. Softune and EUROScope both require that you register the software and obtain a license file - this process is fast and free of charge.
Building the demo application
  1. Open the Demo/MB96340_Softune/96340_FreeRTOS_96348hs.wsp workspace from within the Softune IDE.
  2. Select 'Build' from the IDE Project menu - the demo application should compile with no errors or warnings, although the linking phase will output warning regarding the lack of debug information in the Softune libraries. The linker warning are unavoidable and can be ignored.
Programming the microcontroller Flash memory
  1. Connect the starter kit to your host PC using a USB cable.
  2. Start the Spansion Flash MCU programming utility.
  3. Ensure the correct MCU and crystal frequency are selected - highlighted in red in the image below.
    The Spansion Flash MCU programming utility
  4. Use the 'Open' button (highlighted in blue in the image above) to select the built file Demo/MB96340_Softune/FreeRTOS_96348hs_SK16FX100PMC/STANDALONE/ABS/
    FreeRTOS_96348hs_SK16FX100PMC.mhx
  5. On the Flash programming utility, click 'Set Environment' and ensure that the (virtual) COM port assigned to the USB connection is selected. The Windows Device Manager can be used to check which port was assigned to the USB connection:
    1. Select 'System' from within the Windows Control Panel. System Properties dialogue will open.
    2. Select the 'Hardware' tab of the System Properties dialogue, then click the 'Device Manager' button (highlighted in red in the image below). The Device Manager window will open.
      Opening the Device Manager
    3. Expand the 'Ports (Com and LPT) node within the Device Manager to reveal the port assigned to the Spansion connection (COM4 in the case depicted below).
      Viewing the port assigned to the Spansion USB connection
  6. On the starter kit board, ensure switch S1 is in the programming position (toward the D connectors), then press the blue button to reset the MCU.
  7. Finally, click the 'Full Operation' button within the Flash programming utility (highlighted in yellow in the image above). Programming the flash should not take more than approximately 20 seconds.
  8. To start the program executing, move S1 back to the Run position before pressing the blue button (on the starter kit) once again. Make sure ensure the loopback connector is on X4 (as described under "Demo Application Setup" above) before resetting the board.
Starting a debug session
  1. Following on from the instructions to program the MCU flash - leave the RS232 (or USB virtual COM port) cable in place, and the switch SW1 in the run position.
  2. Ensure the Flash programming utility is no longer running as it will prevent the debugger from accessing the COM port.
  3. Start the EUROScope debugging software.
  4. Select 'Open Application' from the EUROScope file menu, then navigate to and open the Demo/MB96340_Softune/FreeRTOS_96348hs_SK16FX100PMC/STANDALONE/ABS/
    FreeRTOS_96348hs_SK16FX100PMC.abs
    file. Note this time we have opened the .abs file, whereas within the Flash programming utility we opened the .mhx file.
  5. Select 'Select Target Connection' from the Euroscope 'Preferences' menu, then ensure "Fujitsu 16FXBootROM (RS232)" is selected as depicted below.
    Ensure "Fujitsu 16FXBootROM (RS232)" is selected
  6. From the same pop up window (depicted above), click 'Configure' to bring up the RS232 configuration options. [NOTE: I find this locks my PC up for a minute or two - don't panic just wait for the next dialogue box to appear].
  7. Set the communication options as depicted below - although obviously use the COM port that is correct for your host computer, which might not be COM1 as shown below!
    Configuring the communication parameters
  8. Select 'Open' from the EUROScope 'Communications' menu. If all is correct you should be presented with the source and assembly code ready for debugging. If not then click the 'Initialise target and run until main' speed button. If you still cannot see the source code then use the 'Source Paths' option from the EUROScope 'Preferences' menu to ensure EUROScope is attempting to find the source files in the correct location.
  9. Once a debug connection has been established EUROScope can be used to step through the code, view memory, set break points, etc as expected.
The demo application creates 8 co-routines, 31 persistent tasks, and periodically dynamically creates and destroys another 2 tasks. These tasks consist predominantly of the standard demo application tasks (see the demo application section for details of the individual tasks).
  • Check task
  • The trace task
    This task is only included in the build if INCLUDE_TraceListTasks is set to 1 within FreeRTOSConfig.h, and can only be used when executing standalone (not through the debugger).
    The trace task is a user interactive task that writes execution trace and task state information to UART 1. To view the menu and provided information connect UART 1 to a terminal program (such as Hyperterminal) on your host PC. 9600 baud is used.
The SK-16FX-EUROScope hardware contains a 2 * 7 segment numerical display, on which each segment can be controlled separately. In addition to these segments the display contains two '.' characters that can also be controlled separately. These segments and '.' characters provide convenient outputs for the demo tasks that would normally utilise a conventional LED.
  • The 'check' function will toggle the '.' character on the 2 * 7 segment display every 3 seconds.
  • If included in the build, the trace task will send menu options to a terminal program via UART 1.
  • The LED flash tasks use the segments of first character on the display - segments under control of the flash tasks will toggle at constant rate with each task using a different frequency. Three flash tasks are created.
  • The LED flash co-routines use the second character of the display. Again, each co-routine will toggle a segment at a constant rate with each co-routine using a different frequency. Eight co-routines are created.
Optimisation
Please note that the port will not function correctly if the optimisation level is set to 0. This is because level 0 optimisation causes the compiler to insert prologue and epilogue instructions into the interrupt service routines used by the RTOS kernel to switch between tasks, even though the _nosavereg function qualifier is used. If level 0 optimisation is required then these interrupt service routines (contained within the portable layer of the RTOS kernel itself, not within the application code) will require re-writing in pure assembly code.
Register banking
The 16FX port does not use register banking. Only bank 0 is used.
Memory model
The 16FX port can be used with small, medium, compact or large memory models. The definition configMEMMODEL within Demo/MB96340_Softune/FreeRTOS_96348hs_SK16FX100PMC/Src/FreeRTOSConfig.h must be set to portSMALL, portMEDIUM, portCOMPACT or portLARGE to match the project settings.
Selecting the memory model within the Softune IDE - configMEMMODEL must be set to match the selected option
Watchdog
The settings within Demo/MB96340_Softune/FreeRTOS_96348hs_SK16FX100PMC/SRC/watchdog/watchdog.h allow the selection of the method to use.
Resources used by the RTOS
The RTOS yield function uses software interrupt 122.
Configuration items specific to this demo are contained in Demo/MB96340_Softune/FreeRTOS_96348hs_SK16FX100PMC/Src/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
Each port #defines 'BaseType_t' to equal the most efficient data type for that processor. This port defines BaseType_t to be of type short (16 bits).
Unlike most ports, interrupt service routines that cause a context switch have no special requirements and can be written as per the compiler documentation. The macro portYIELD_FROM_ISR() can be used to request a context switch from within an ISR. See Demo/MB96340_Softune/FreeRTOS_96348hs_SK16FX100PMC/Src/serial/serial.c for an example.
Set the definition configUSE_PREEMPTION within Demo/MB96340_Softune/FreeRTOS_96348hs_SK16FX100PMC/Src/FreeRTOSConfig.h to 1 to use pre-emption or 0 to use co-operative.
Serial driver
