FreeRTOS LTS:
RISC-V RV32M1 VEGAboard Demo (RI5CY Core)
RISC-V RV32M1-Vega Pulp RI5CY Core
This page documents a pre-configured FreeRTOS Eclipse/GCC project that targets a RISC-V core on the RV32M1 VEGAboard. The RV32M1 incorporates a PULP RI5CY RISC-V core, a PULP Zero RISCY RISC-V core, an Arm Cortex-M4 core, and an Arm Cortex-M0+ core. At the time of writing this demo only targets the RI5CY RISC-V core.
IMPORTANT! Notes on using the FreeRTOS Pulp RI5CY RISC-V port
  2. Source code organisation
  3. The RTOS demo application functionality
  4. Building and running the RTOS demo application
The FreeRTOS zip file download contains the source code for all the FreeRTOS ports, and every demo application. That means it contains many more files than are required to use the FreeRTOS VEGAboard RI5CY RISC-V port. See the Source Code Organization page for information on the zip file's directory structure. The Eclipse project is located in the /Demo/RISC-V_RV32M1_Vega_GCC_Eclipse directory. More information is provided in the build instructions section below.
On RISC-V architectures the additional freertos_risc_v_chip_specific_extensions.h header file is used to extend the base RISC-V RTOS port to any chip specific extensions the target RISC-V chip may implement. The RI5CY RISC-V core used on the RV32M1 VEGAboard includes six additional additional registers over and above those defined by the base RISC-V architecture, and does not include a CLINT. Therefore this project uses the freertos_risc_v_chip_specific_extensions.h header file from the /FreeRTOS/Source/portable/GCC/RISC-V/chip_specific_extensions/Pulpino_Vega_RV32M1RM directory.
The VEGAboard RI5CY RISC-V Demo Application
    The queue send task is implemented by the prvQueueSendTask() function. The task sits in a loop sending the value 100 to the queue every 1000 milliseconds (1 second).
    The queue receive task is implemented by the prvQueueReceiveTask() function. The task sits in a loop that blocks on attempts to read from the queue (no CPU cycles are consumed while the task is blocked), writing 'blink' to the VEGAboard's UART and toggling an LED each time the value 100 is received from the queue send task. As the queue send task writes to the queue every 1000 milliseconds the queue receive task unblocks and both writes to the UART and toggles the LED every 1000 milliseconds.
A 'check' task is created that periodically inspects the standard demo tasks (which contain self monitoring code) to ensure all the tasks are functioning as expected. The check task toggles the LED and outputs either a '.' character or error messagto the UART each time it executes. This gives visual feedback of the system health. If the LED is toggling every 3 seconds, then the check task has not discovered any problems. If the LED is toggling every 500 milliseconds, then the check task has discovered a problem in one or more tasks, and the UART will output an error message instead of '.'.
Building and debugging the demo application
To open and build the RI5CY project:
  1. Follow the instructions on the open-isa.org web site to install the necessary GCC, OpenOCD and Eclipse development tools, and connect the host computer (the computer running the development tools) to the target hardware (the VEGAboard). More detailed instructions on configuring the Eclipse environment with the relevant tools can be found in this open-isa guide.
  2. Start Eclipse and either select an existing or create a new workspace when prompted.
  3. Select "Import..." from the Eclipse 'File' menu. The Import dialog box will open.
  5. In the Import Projects dialog box, navigate to and select the FreeRTOS/Demo/RISC-V_RV32M1_Vega_GCC_Eclipse/projects/RTOSDemo_ri5cy directory, and ensure the 'copy projects into workspace' check box is not checked.
  6. In the 'Projects' window of the Import Projects dialog box, select the RTOSDemo_ri5cy project, and click finish.
  7. Select "Build all" from the Eclipse 'Project' menu. The project should build without any errors or warnings, and output a file called RTOSDemo_ri5cy.elf.
  8. Finally, to start a debug session, right click the "RTOSDemo_ri5cy.launch" file in the Eclipse project explorer, then select "Debug As->RTOSDemo_ri5cy" from the pop up menu.
    Selecting "Debug As->RTOSDemo_ri5cy" from the pop up windows after right clicking "RTOSDemo_ri5cy.launch". Click to enlarge.
  • Configuration items specific to this demo are contained in FreeRTOS/Demo/RISC-V_RV32M1_Vega_GCC_Eclipse/projects/RTOSDemo_ri5cy/FreeRTOSConfig.h. The constants defined in that file can be edited to suit your application. In particular configCLINT_BASE_ADDRESS and configMTIMECMP_BASE_ADDRESS are set to 0 because the RI5CY core on the VEGAboard does not include a machine timer (MTIMER).
  • The RI5CY core has six additional registers over and above the registers defined by the base RISC-V architecture. These registers are saved and restored by the macros contained in the freertos_risc_v_chip_specific_extensions.h header file located in the /FreeRTOS/Source/portable/GCC/RISC-V/chip_specific_extensions/Pulpino_Vega_RV32M1RM directory, so that directory is in the assembler's include path.
  • The interrupt handler provided in the VEGAboard's software development kit (SDK) is called SystemIrqHandler(), so the assembler's command line options include -DportasmHANDLE_INTERRUPT=SystemIrqHandler.
  • The VEGAboard includes a vectored interrupt controller. The file FreeRTOS_startup_RV32M1_ri5cy.S is an edited version of startup_RV32M1_ri5cy.S that sets the FreeRTOS trap handler as the interrupt handler for each vector. The FreeRTOS trap handler is called freertos_risc_v_trap_handler().
  • The file RV32M1_ri5cy_flash.ld is a version of the linker script provided with the board, edited to add the __freertos_irq_stack_top linker variable necessary to ensure the stack that was used by main before the scheduler starts is reused as the interrupt stack after the scheduler starts.
Other notes:
