FreeRTOS LTS:
ARM Cortex-R5 Xilinx UltraScale MPSoC
This page documents a FreeRTOS demo application that targets an ARM Cortex-R5 core on a Xilinx Zynq UltraScale+ MPSoC. A similar project that targets a 64-bit ARM Cortex-A53 core on the same device is provided separately.
The demo uses a standalone BSP (which is the Board Support Package generated by the SDK), and builds FreeRTOS as part of the application. The hardware design project targets the Xilinx ZCU102 Evaluation board.
FreeRTOS is also distributed as part of the Xilinx SDK package, and the SDK includes wizards to generate FreeRTOS for the UltraScale+ MPSoC's 64-bit ARM Cortex-A53, ARM Cortex-R5 and Microblaze cores. If a FreeRTOS project is created using the SDK wizard then FreeRTOS is built as part of the BSP instead of as part of the application. Instructions on creating a FreeRTOS BSP are also provided on this page.
The ARM Cortex-R5 FreeRTOS port implements a full interrupt nesting model, and supports the vectored floating point unit (VFP/FPU).
IMPORTANT! Notes on using the FreeRTOS ARM Cortex-R5 port
  3. Build Instructions
Also see the FAQ My application does not run, what could be wrong?, and the page that provides instruction on using FreeRTOS on ARM Cortex-A embedded processors as the information on running the RTOS on an ARM Cortex-A core is also applicable to running the RTOS on an ARM Cortex-R core.
The FreeRTOS download contains the source code for all the RTOS ports, and all the RTOS demo applications. That means the download contains many more source files than are required to use the Zynq UltraScale+ Cortex-R5 MPSoC port and demo application. See the Source Code Organization section of this web site for a description of the downloaded files.
The directory structure used by the ARM Cortex-R5 demo application is shown and described below. The root CORTEX_R5_UltraScale_MPSoC directory is located in FreeRTOS/Demo.
  +-RTOSDemo_R5               Contains the SDK project and C files specific to the demo.
  +-RTOSDemo_R5_bsp           Contains the hardware board support package.
  • The projects contained in the ZynqMP_ZCU102_hw_platform and RTOSDemo_R5_bsp directories were created by the Xilinx SDK.
  • The RTOSDemo_R5 directory only contains the source files that are specific to the Zynq UltraScale+ MPSoC demo. The FreeRTOS source files, and the source files that implement tasks that are common to all demo applications, are located elsewhere in the directory tree. The project will only build if the default directory structure is unchanged. Also see the page that describes how to use virtual and linked paths in the Eclipse project explorer.
The Zynq UltraScale+ MPSoC ARM Cortex-R5 Demo Application
The constant mainSELECTED_APPLICATION, which is #defined at the top of main.c, is used to switch between a basic and simply Blinky style demo, and a more comprehensive test and demo application.
If mainSELECTED_APPLICATION is set to 0 then main() will call main_blinky(), which is implemented in the main_blinky.c C source file.
main_blinky() implements a very simple example that uses two tasks and one queue. One task uses the queue to repeatedly send the value 100 to the other task. The receiving task simply prints a message to the USB UART port (J83) each time it receives the message. 115200 baud is used.
The value 100 is sent to the queue every 200 milliseconds, so the message is printed to the UART every 200 milliseconds.
If mainSELECTED_APPLICATION is set to 1 then main() will call main_full(), which is implemented in the main_full.c C source file.
The majority of the tasks created by the comprehensive demo are from the set of standard demo tasks, which are common to all the RTOS demo applications. They have no specific functionality or purpose other than to demonstrate the FreeRTOS API being used, and test the RTOS architecture and compiler port.
The following tasks are also created:
    Timers are used to test interrupt nesting, and test RTOS queues being used from nested interrupts. The demo generates the RTOS tick interrupt from TTC timer 0, so the interrupt nesting test uses TTC timers 2, 3 and 4.
  • Register test tasks
    The register test tasks test the RTOS context switch mechanism. They start by filling all the ARM Cortex-R5 ALU and FPU register with known and unique values, then repeatedly check that the values originally written to the registers remain unchanged for the lifetime of the task. The nature of the register check tasks necessitates that they are written in assembly code.
  • A 'check' task
    The check task periodically queries the standard demo tasks, and the register check tasks, to ensure they are still executing and functioning as intended, and then prints a status message to the USB UART (J83). 115200 baud is used.
    The output generated when the RTOS demo is executed on an ARM Cortex-R5 core of the Zynq UltraScale+ MPSoC
Hardware setup
The demo is configured to download and run the generated executable over the JTAG interface. To enable JTAG booting all four switches on bank SW6 need to be set toward the centre of the board.
Build Instructions - Using a Standalone BSP
This section describes how to build the demo described immediately above, which is found in the official FreeRTOS download. The section that follows after describes how to create a project using the Xilinx SDK, in which case the FreeRTOS source files are built as part of the BSP.
Importing the RTOS demo project into the SDK Eclipse workspace
  2. In the next dialogue box, select FreeRTOS/Demo/CORTEX_R5_UltraScale_MPSoC as the root directory. Then, make sure the RTOSDemo_R5, RTOSDemo_R5_bsp and ZynqMP_ZCU102_hw_platform projects are checked in the "Projects" area, and that the Copy Projects Into Workspace box is not checked, before clicking the Finish button (see the image below for the correct check box states).
    Importing the free ARM Cortex-R5 RTOS Demo Source project into the Xilinx SDK
    The ZynqMP_ZCU102_hw_platform and RTOSDemo_R5_bsp projects are dependencies of the RTOSDemo_R5 project, so only the RTOSDemo_R5 project needs to be built explicitly.
    The ARM Cortex-R5 RTOS projects viewed in the Eclipse project explorer.
Starting a debug session
  1. Ensure the ZCU102 target hardware is powered up and connected to the host computer using an appropriate debug interface.
    ARM Cortex-R5 RTOS demo Eclipse target setup tab
    ARM Cortex-R5 RTOS demo Eclipse application tab
  6. Click the "Debug" button to commence debugging. The application will be downloaded to RAM and the debugger will break on entry to main(). It may be necessary to select the correct ARM Cortex-R5 core in the Debug window in order to see the correct source code, and use the debugging controls.
    Selecting the ARM Cortex-R5 core in order to debug the RTOS project
    Selecting the ARM Cortex-R5 0 core in the Debug window
Build Instructions - Creating a FreeRTOS BSP
The previous section described how to build the RTOS project that comes in the main FreeRTOS zip file download. FreeRTOS also ships with the Xilinx SDK. This section describes how to create a FreeRTOS project for an ARM Cortex-R5 core using the SDK.
    Creating a new RTOS project
  2. In the New Project dialogue box, first select "psu_cortexr5_0" as the processor, then select the hardware platform as appropriate, and finally select freertos as the OS platform before clicking "Next". The New Project Templates dialogue will appear.
    The required New Project settings to create an ARM Cortex-R5 RTOS project
    RTOS template for ARM Cortex-R5 RTOS port
Configuring a FreeRTOS BSP
FreeRTOS ARM Cortex-R port specific configuration
Attention please!: A separate page provides information on running the RTOS on an ARM Cortex-A core. The information on that page is also relevant to running the RTOS on an ARM Cortex-R core. Pay particular attention to the value and meaning of the configMAX_API_CALL_INTERRUPT_PRIORITY setting.
Configuration items specific to this demo are contained in /FreeRTOS/Demo/CORTEX_R5_UltraScale_MPSoC/RTOSDemo_R5/src/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application.
Interrupt vector table
By default, SDK projects define the interrupt vector table as part of the BSP. This makes it difficult to install the FreeRTOS handlers using the methods described on the page about running FreeRTOS on ARM Cortex-A (and ARM Cortex-R) embedded processors. Therefore, this demo defines its own interrupt vector table in FreeRTOS_asm_vectors.S, and the linker script contains an edit to ensure the FreeRTOS vector table is used instead of the vector table defined by the BSP.
This demo uses drivers provided by Xilinx to configure the interrupt controller, and install application defined interrupts. Examples can be found in FreeRTOS/Demo/CORTEX_R5_UltraScale_MPSoC/RTOSDemo_R5/src/Full_Demo/IntQueueTimer.c, which implements and installs the interrupt service routines used by the interrupt nesting test.
Information is provided on the Using FreeRTOS on ARM Cortex-A Embedded Processors page. This demo is configured to generate the tick interrupt from TTC channel 0.
The FreeRTOSConfig.h header file used by the demo has both configSUPPORT_STATIC_ALLOCATION and configSUPPORT_DYNAMIC_ALLOCATION defined, and the demo shows both methods being used. Source/Portable/MemMang/heap_4.c is included in the ARM Cortex-R5 demo application project to provide the memory allocation required when objects are created using dynamic memory allocation. Please refer to the Memory Management section of the API documentation for full information.
