LPC1768 ARM Cortex-M3 CrossWorks Demo
[Embedded Ethernet Examples]
This page presents a Rowley CrossWorks FreeRTOS web server and USB demo that is pre-configured to run on the Keil MCB1700 evaluation board. The MCB1700 uses an LPC1768 Cortex-M3 microcontroller from NXP.
The demo uses:
  • The Rowley CrossWorks IDE version 2.0.
I tested the development environment using both an Amontec JTAGKey-Tiny and a CrossConnect for ARM. Both worked well, although the Amontec device was many times slower.
The CrossWorks project for the LPC1768 demo is called RTOSDemo.hzp and is located in the FreeRTOS/Demo/CORTEX_LPC1768_GCC_Rowley directory.
web server configuration
Connect the MCB1700 target to a computer running a web browser either directly using a point to point (crossover) cable, or via a Ethernet switch using a standard Ethernet cable.
The IP address used by the demo is set by the constants configIP_ADDR0 to configIP_ADDR3 within the file FreeRTOS/Demo/CORTEX_LPC1768_GCC_Rowley/FreeRTOSConfig.h. The MAC address and net mask are configured within the same header file.
The IP addresses used by the web browser computer and the MCB1768 development board must be compatible. This can be ensured by making the first three octets of both IP addresses identical. For example, if the web browser computer uses IP address 192.168.100.1, then the development board can be given any address in the range 192.168.100.2 to 192.168.100.254 (barring any addresses already present on the network).
  1. Open FreeRTOS/Demo/CORTEX_LPC1768_GCC_Rowley from within the CrossStudio IDE.
  2. Connect the MCB1700 to the host computer using your choice of debug interface - then connect to the target by selecting "Connect" from the "Target" menu.
  3. Select "Build and Debug" from the "Build" menu - the demo application should build with no errors or warnings before being programmed into the microcontroller Flash memory. The debugger will break on entry to main().
The demo application creates 36 tasks before starting the RTOS scheduler. The tasks consist mainly of the standard demo tasks (see the demo application section for details of the individual tasks). Their only purpose is to test the RTOS kernel port and provide a demonstration of how to use the various API functions.
  • uIP task
  • USB task
  • LEDs P2.2, P2.3 and P2.4 are under the control of the standard 'flash' tasks. Each will toggle at a different but fixed frequency.
  • The USB device port of the MCB1700 will enumerate as a CDC class device. To use the USB port (assuming a Windows host computer):
    1. Connect the MCB1700 to your host computer using the USB device port of the MCB1768 (ensuring the jumpers are set correctly for device operation).
    2. The host computer should recognise the new USB connection and prompt for the location of a suitable .inf file. Select the option to manually select the .inf file location, then browse to usbser.inf which is located in the FreeRTOS/Demo/CORTEX_LPC1768_GCC_Rowley directory. Assuming usbser.sys is available on your host computer the CDC device will be assigned a COM port number. The Windows Device Manager can be used to ascertain the actual number assigned.
Note that the LCD is not used because the LCD driver is only permitted to be used with the Keil compiler.
Served Web Pages
The served IO page
The IO page provides a simple interface that permits data to be sent to an LED. The check box permits the state of the user LED to be both set and queried. Changes are sent to the target hardware by clicking the "Update IO" button.
Configuration items specific to these demos are contained in FreeRTOS/Demo/CORTEX_LPC1768_GCC_Rowley/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
Unlike most ports, interrupt service routines that cause a context switch have no special requirements and can be written as per the compiler documentation. The macro portEND_SWITCHING_ISR() can be used to request a context switch from within an ISR. An example interrupt service routine called vEMAC_ISR() is provided in FreeRTOS/Demo/CORTEX_LPC1768_GCC_Rowley/webserver/emac.c. This should be used as a reference example.
Set the definition configUSE_PREEMPTION within FreeRTOS/Demo/CORTEX_LPC1768_GCC_Rowley/FreeRTOSConfig.h to 1 to use pre-emption or 0 to use co-operative.
