FreeRTOS LTS:
NXP LPC43xx ARM Cortex-M4F Demo
Using Keil MDK development tools
NXP LPC4300 family of microcontrollers
This page documents a FreeRTOS ARM Cortex-M4F demo application that targets an NXP LPC43xx microcontroller. A Keil project is provided that is pre-configured to run on the LPC4350 development board provided by Hitex. The LPC4350 demo project will evolve over the coming weeks to also include support for the LPC4350's ARM Cortex-M0 based co-processor.
The demo configures the LPC4350 to run at 204MHz. See the notes in the RTOS configuration and usage section below.
The FreeRTOS ARM Cortex-M4F port supports a full interrupt nesting model, and never completely disable interrupts. The port can only be used with hardware floating point support turned on in the compile time options of the project used to build the source files. ARM Cortex-M4 devices that don't include a floating point unit should not use this port, but instead use the FreeRTOS ARM Cortex-M3 port layer.
Note that Keil MDK version 4.2.2 or above is required to ensure the no_allow_fpreg_for_nonfpdata compiler option is available.
IMPORTANT! Notes on using the FreeRTOS Keil LPC4300 demo project
The FreeRTOS zip file download contains source code for all the FreeRTOS ports, and every demo application project. It therefore contains many more files than are required to build and run the NXP LPC4350 demo. See the Source Code Organization section for a description of the downloaded files, and information on creating a new project.
The Keil MDK demo project for the ARM Cortex-M4F core on the LPC4350 is called M4.uvproj, and is located in the FreeRTOS/Demo/CORTEX_M4F_M0_LPC43xx_Keil/M4 directory of the official FreeRTOS .zip file download. The FreeRTOS/Demo/CORTEX_M4F_M0_LPC43xx_Keil/M0 directory is currently empty, and included as a placeholder for the near future addition of support for the LPC4350's co-processor core.
The NXP LPC4350 Demo Application
The demo application can be configured to provide a very simply 'blinky' style demonstration, or a full and comprehensive test and demonstration of the FreeRTOS functionality. The configuration built is controlled by the constant #define mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY, which is defined in main.c.
Demo application tasks are split between standard demo tasks, and demo specific tasks. Standard demo tasks are used by all FreeRTOS ports and demo applications. They have no specific purpose, other than to demonstrate the FreeRTOS API, and test the port.
Description
Set to 1 This creates a very simple example that creates three standard demo "flash" tasks. Each of the three tasks toggles an LED at a fixed but different frequency. LEDs LED3, LED2 and LED1 are used.
Set to 0 This is a very comprehensive demo that creates 46 tasks before starting the RTOS scheduler. It then continuously creates and deletes a further two tasks while the application is executing.
The demo includes a lot of queues, a software timer, and various different types of semaphore. The tasks consist mainly of the standard demo tasks.
Application specific "register test" tasks are also created. These start by filling all the generic, and all the floating point registers, with known values. The tasks then repeatedly check that each register maintains the value written to it for the lifetime of the task. The tasks run at the idle priority, so will exit and re-enter the Running state often. The two register check tasks each use different values, and a register containing an unexpected value is symptomatic of an error in the context switching mechanism.
A 'check' software timer is created that periodically inspects the standard demo tasks, and register test tasks, to ensure all the tasks are functioning as expected. The check software timer's callback function toggles LED LED0. This gives visual feedback of the system health. If LED LED0 is toggling every 3 seconds, then the check software timer has not discovered any problems. If LED LED0 is toggling every 200 milliseconds, then the check software timer has discovered a problem in one or more tasks.
Like the simple flasher demo, the comprehensive demo creates the standard demo flash tasks, which toggle LEDs LED3, LED2 and LED1 at fixed but different frequencies.
The demo uses the LEDs that are soldered directly onto the Hitex PCB, so no hardware set up is required.
  1. Ensure the target hardware is connected to the host computer using a suitable interface. The project has been tested with both a ULINK2 and a ULINK ME.
  2. Open the M4.uvproj Keil project from within the Keil IDE.
  3. Select "Build" from the IDE's "Project" menu, or simply press F7. The project should build without any errors or warnings.
  4. When the build completes, select "Start/Stop Debug Session" from the IDE's "Debug" menu (or just press CTRL+F5) to program the microcontroller flash memory, and start a debug session. The execution will break on entry to the main() function.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_M4F_M0_LPC43xx_Keil/M4/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
    Whereas configKERNEL_INTERRUPT_PRIORITY and configMAX_SYSCALL_INTERRUPT_PRIORITY are full eight bit shifted values, defined to be used as raw numbers directly in the ARM Cortex-M4F NVIC registers, configLIBRARY_LOWEST_INTERRUPT_PRIORITY and configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY are exact equivalents, but defined using just the 5 priority bits available on the LPC4300. The CMSIS library function NVIC_SetPriority() requires the unshifted 5 bit format.
The lowest priority on a ARM Cortex-M core is in fact 255 - however different Cortex-M vendors implement a different number of priority bits and supply library functions that expect priorities to be specified in different ways. For example, on LPC ARM Cortex-M microcontrollers, the lowest priority you can specify is in fact 31 - this is defined by the constant configLIBRARY_LOWEST_INTERRUPT_PRIORITY in FreeRTOSConfig.h. The highest priority that can be assigned is always zero.
It is also recommended to ensure that all five priority bits are assigned as being preemption priority bits, and none as sub priority bits, as they are in the provided demo.
Core clock configuration
The demo runs the LPC4350 clock at 204MHz. To achieve this it is necessary for the functions that configure the parallel flash memory controller to execute out of RAM. The mapping of these functions is performed within the linker script itself (scatter file), and the code that steps the core clock up to 204MHz is contained in Hitex_fast_startup.c.
