Using IAR and Keil - Including an embedded web server with CGI scripting
[Embedded Ethernet Examples]
Microsemi SmartFusion A2F200M3 Evaluation Board A2F-EVAL-KIT
This page documents a FreeRTOS ARM Cortex-M3 demo application that targets the Microsemi (formally Actel) SmartFusion mixed signal FPGA with integrated ARM Cortex-M3 microcontroller subsystem.
FreeRTOS includes ARM Cortex-M3 ports for the IAR, Keil and GCC compilers. Demo application projects targeting the SmartFusion are provided for the IAR Embedded Workbench, Keil MDK and SoftConsole (Eclipse) IDEs. This page provides instruction on using the IAR and Keil IDEs only. A separate page provides instructions on using the SoftConsole Eclipse IDE.
The IAR and Keil projects are pre-configured to run on the A2F-EVAL-KIT SmartFusion evaluation board.
IMPORTANT! Notes on using the FreeRTOS IAR and Keil SmartFusion example projects
The IAR Embedded Workbench workspace for the SmartFusion A2F demo is called RTOSDemo_IAR.eww, and is located in the FreeRTOS/Demo/CORTEX_A2F200_IAR_and_Keil directory.
The Keil MDK project for the SmartFusion A2F demo is called RTOSDemo_Keil.uvproj, and is also located in the FreeRTOS/Demo/CORTEX_A2F200_IAR_and_Keil directory.
The FreeRTOS zip file download contains source code for all the FreeRTOS ports, and every demo application project. It therefore contains many more files than are required to build and run the SmartFusion demo. See the Source Code Organization section for a description of the downloaded files, and information on creating a new project.
The two tasks communicate via a queue, with the receiving task toggling an LED each time a value is received.
Pressing user button SW1 generates an interrupt, the service routine for which resets a software timer before turning an LED on. The software timer has a five second period, and when the five seconds expire, the timer callback function turns the LED off again. Therefore, pressing SW1 will turn the LED on, and the LED will remain on until a full five seconds pass without the button being pressed again.
The Full build configuration creates yet more tasks that are neither part of the Blinky configuration or the set of standard demo tasks. These additional tasks are described briefly below this table.
Full_with_optimisation The functionality of the Full_with_optimisation build configuration is identical to that of the Full build configuration. The compiler optimisation setting is the only difference between the two.
Tasks and timers that are created by both Full build configurations, that are not part of either the Blinky demo, or the standard demo tasks, include:
    Each time the check timer expires, its associated callback function queries the status of all the running standard demo tasks. If any queried status is returned as 'failed', then the period of the Check timer is shortened to 500ms from its original setting of 3 seconds.
    The check timer callback toggles LED D8 each time it executes. Therefore, if LED D8 toggles every three seconds, then no errors have been discovered. If LED D8 toggles every 500ms, then at least one standard demo task has reported an error. The name of the standard demo task that reported the error can be viewed using the embedded web server - it is displayed at the bottom of the "task stats" web page, under the task stats table.
  • uIP task
  • OLED task
    The OLED task scrolls a message across both rows of the OLED.
Web server configuration
The demo application includes an embedded web server. The IP address used by the web server is fixed, and set set by the constants configIP_ADDR0 to configIP_ADDR3. The definition of these constants can be found near the bottom of the FreeRTOSConfig.h header file, which is itself located in the same directory as the IAR and Keil demo project files. Constants that define the MAC address, and the NET mask, are located in the same header file.
The IP addresses used by the web server running on the SmartFusion device, and the web browser used to connect to the web server, must be compatible with each other. To ensure this is the case, make the first three octets of both IP addresses the same. For example, if the web browser computer uses IP address 10.10.10.1, then the SmartFusion device can be given any IP address in the range 10.10.10.2 to 10.10.10.254 - other than any IP addresses that are already present on the same network.
This section provides instructions on the hardware set up required to program an application into the ARM Cortex-M3 flash memory. It is assumed that the FPGA fabric and ACE are already configured correctly, which will be the case if the configuration has not been changed from that shipped. However, if the FPGA fabric or ACE configuration has been altered from that shipped, and you find the demo application does not execute correctly, then it is recommended to restore the FPGA fabric and ACE configuration using the .pdb file supplied with the A2F-EVAL-KIT.
  1. Ensure jumpers JP7 and JP10 are set to the RVI and M3 positions respectively.
  2. If you are using the IAR Embedded Workbench, then connect a J-Link debugger interface to the connector labelled "RVI-HEADER".
    If you are using the Keil MDK, then connect a U-Link debugger interface to the connector labelled "RVI-HEADER".
  3. Use an Ethernet cable to connect the A2F-EVAL-KIT hardware to a computer running a standard web browser. This needs to be done either directly, by using a crossover (point to point) Ethernet cable, or through a hub/switch, using a standard Ethernet cable. Only the direct connection option was tested during development of the demo, but both methods should work.
  4. Power the A2F-EVAL-KIT using the USB connector J14.
  2. If you wish to use the embedded web server, then select either the Full or the Full_with_optimisation build configuration. If you want to start with a very simple example, then select the Blinky build configuration.
  2. If you wish to use the embedded web server, then select either the Full or the Full_with_optimisation build configuration. If you want to start with a very simple example, then select the Blinky build configuration. (Build configurations are called 'targets' in the MDK environment).
Demo functionality
Served web Pages
The served IO page
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_A2F200_IAR_and_Keil/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
