FreeRTOS LTS:
ColdFire V2 RTOS Demo
Using Eclipse and GCC
This page presents the new FreeRTOS port and demo application for the V2 ColdFire core from Freescale. This new port, first provided with FreeRTOS V5.0.4, has extended functionality and therefore supersedes ports provided in previous versions.
The previous V2 port has been retained in the FreeRTOS download but is not recommended for new designs. The new port is almost a 'drop in' replacement so upgrading old designs should be simple, with only the interrupt service routine semantics (described on this page) requiring some consideration (writing interrupts is now simpler).
IMPORTANT! Notes on using the V2 ColdFire RTOS port
  1. Source Code Organization
The Eclipse workspace for the ColdFire MCF5282 Eclipse demo is contained in the FreeRTOS/Demo/ColdFire_MCF5282_Eclipse directory.
The linker script is configured to place executable code in the M5282EVB SDRAM (not the fastest place to run code from!) and data in the internal SRAM of the MCF8252 itself. All switches in the SW1 bank can therefore be set to their 'ON' position.
The demo application uses the LEDs built onto the evaluation board so jumpers JP12 to JP15 should be in place.
The demo application includes an interrupt driven UART test where one task transmits characters that are then received by another task. For correct operation of this functionality a loopback connector must be fitted to the AUXILIARY connector of the M5282EVB hardware (pins 2 and 3 must be connected together on the 9Way connector - a paper clip is normally sufficient for the purpose).
The demo application creates 42 tasks before starting the RTOS scheduler (including the idle task), then repeatedly dynamically creates and deletes a further two tasks when the RTOS kernel is running.
The standard demo tasks do not perform any particular function other than to serve as usage examples for each FreeRTOS API function.
  • LEDs marked D6, D7 and D8 are under control of the very simple 'flash' tasks. Each will flash at a constant frequency, with LED D6 being the fastest and LED D8 being the slowest.
  • Most of the tasks do not update an LED so have no visible indication that they are operating correctly. Therefore a 'Check' task is created whose job it is to ensure that no errors have been detected in any of the other tasks. The check task only executes every few seconds, but has a high priority so is guaranteed to get processing time when required. The check task will toggle LED D9 once every 5 seconds if all the demo tasks are executing as expected. The toggle rate will increase to 500ms should an error be detected in any task. This mechanism can be tested by removing the loopback connector from the AUXILIARY port to deliberately generate an error.
More information is provided in the comments of the code itself.
The RTOS kernel is configured to use interrupt priority level 1. The UART uses interrupt priority level 2. Interrupt nesting is further exercised by the 'IntQueue' test whereby one task and two interrupts all access the same two queues. The two interrupts run at priority levels 4 and 3 respectively so the maximum possible interrupt nesting depth is 4. See the RTOS Configuration and Usage section for a more complete explanation of the executing interrupts and their respective priorities.
      The Eclipse workspace for the ColdFire MCF5282 Eclipse demo is contained in the FreeRTOS/Demo/ColdFire_MCF5282_Eclipse directory. This is therefore the directory that should be selected when Eclipse asks you for a workspace location, as depicted below.
    5. Select "Build All" from the Eclipse "Project" menu item. The demo should build with no errors or warnings.
  • To run the demo application:
    1. Ensure your M5282EVB is correctly connected to your host computer using a BDM interface supported by the CodeSourcery debug sprite.
    2. Press the down arrow next to the speed button that shows a little bug, then select RTOSDemo from the menu.
      You should be taken to the Eclipse Debug perspective, if you are not already there.
      Wait for the program to be loaded into the evaluation board RAM - a progress bar in the bottom right corner of the IDE will show you when this is complete.
      Waiting for the program to load
      Once loaded the program should break on entry to main(). The Eclipse IDE can then be used to step through the code, view variables, view memory, etc, just as any other debug IDE. Manually remove the breakpoint at main() as a new break point will be added each time a debug session is started.
Configuration items specific to this demo are contained in FreeRTOS/Demo/ColdFire_MCF5282_Eclipse/RTOSDemo/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
The UART1 interrupt (listing 1 below) within the MCF5282 demo can be used as an example:
unsigned char ucChar;
        xDoneSomething = pdFALSE;
        == pdTRUE )
                /* Send the next char. */
                MCF_UART1_UTB = ucChar;
                is being transmitted. */
                MCF_UART1_UIMR = serRX_INT;
                xTxHasEnded = pdTRUE;
            ucChar = MCF_UART1_URB;
    unblock. */
Listing 1: An example ISR
In RTOS addition the RTOS kernel requires one additional interrupt vector. As delivered vector 16 on interrupt controller 0 is used as on the MCF5282 vector 16 is not used by any peripherals and is therefore spare. The RTOS kernel uses this vector in conjunction with the Interrupt Force Register 0 (INTFRCL0). For reasons of efficiency the RTOS kernel assumes it has exclusive access to this register and therefore does not attempt to maintain its state - although this behaviour can be easily altered by using bitwise sets and clears on the register rather than writing to the register in its entirety.
Critical sections
Execution context
Set the definition configUSE_PREEMPTION within FreeRTOS/Demo/ColdFire_MCF5282_Eclipse/RTOSDemo/FreeRTOSConfig.h to 1 to use pre-emption or 0 to use co-operative. The demo application will only execute correctly with configUSE_PREEMPTION set to 0 if configIDLE_SHOULD_YIELD is set to 1.
